Samsung HC-P4241W 42 in. Rear Projection HDTV-Ready Television
Problem for Samsung HC-P4241W 42 in. Rear Projection HDTV-Ready...
Problems with Samsung HC-P4241W 47 in. Rear
By redstepside on Jul 29, 2009
Problems with Samsung HC-P4241W 47 in. Rear Projection HDTV-Ready trying to manually adjust the convergence.Is there a way to enter a 32 point adjustment instead of a 72 point adjustment?The 72 point adjustment only seems to make it worse.
Comments:
Jul 31, 2009
- thanks Guru....I have done this but its way too far off I think to get it back to spec....The colors are alot better now but the picture is still crooked.I assuming the board is good but needs the final adjustment to make it right.
Best Solution
posted on Jul 30, 2009
Helpful)
Sparko1
Rank: Guru
Rating: 90%, 66 votes
To get TV into convergence menu hit mute 183 on remote. If you still cannot get it right you will need to replace the convergence amp IC's.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Samsung HC-P4241W 42 in. Rear
Questions and Unsolved Problems for Samsung HC-P4241W 42 in. Rear
Do you recommend Samsung HC-P4241W 42 in. Rear Projection HDTV-Ready Television?
Answer
Answer
after changing the SSB that fixed the original problem I found that there is a bow at the top of the... (More)
Answer
Television just turned off so took back off and vacuumed out all of the dust. Seems to be running... (More)
Answer
the picture is to big for the screen and the picture is darker than normal and the people and the... (More)
Answer
no picture just a noise steady when u try to power on and the dvd player below will not work or even... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HC-P4241W 42 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
