Question about Hunter 20347 Ceiling Fan
The fan motor/bracket that attaches to the mounting bracket is broke and i would like to know if this can be replaced
    New Friend:
  • 63 Answers
Call Hunter (800)893-9330 for a new bracket. They should replace the damaged bracket for free or a nominal fee. They have a potential liability if the bracket is defective. If you broke it, that's another story.
Posted on Jul 29, 2009
How do I remove fan mounted close to ceiling?
There should be side mounting screws in the canopy which attach it to the mounting bracket. The screws are removed to allow the canopy and motor assembly to drop down free of the mounting bracket. A convenient hook is provided to allow wires to be disconnected.
Oct 23, 2015 | Hunter 20461 Brushed Nickel Ceiling Fan
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
REFRIGERATOR AND FREEZER NOT GETTING COLD. ERROR CODE 5Y.MODEL NUMBER LGUS2642LF2 SERIAL NUMBER 4A23305873
That error code is "SY" and not "5Y" and it is for the evaporator sensor error. You will need to replace the sensor.Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Access the evaporator assembly cover in the rear of the freezer section. In convertible units that can function either as refrigerators or freezers, and is located toward the bottom of the unit on the inner back wall -- if necessary, remove the two lower glass shelves and the crisper compartments.
Remove the screws securing the evaporator cover to the freezer wall, using a Phillips screwdriver.
Pull the evaporator cover away from the wall just enough to access the electrical connection behind the cover. Be careful not to damage the gaskets on either side of the evaporator cover. Reach behind the cover and disconnect the electrical connection from its wiring harness. Remove the evaporator cover from the freezer.
Remove the wires inside the exposed evaporator assembly from their retaining clips, then squeeze the quick-connect mechanism to detach the wires from the fan motor.
Remove the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using a 5/16-inch socket or nut driver.
Remove the two hex-head screws holding the fan motor to the mounting bracket, using the 5/16-inch socket or nut driver, then pull the fan blade off the motor shaft.
Examine the fan to make sure the blades are not damaged; if necessary, replace the fan itself as well as the motor. Slide the fan onto the motor shaft.
Attach the new motor to the mounting bracket, using the 5/16-inch socket or nut driver to secure the two hex-head screws.
Replace and tighten the two hex-head screws that hold the fan motor mounting bracket to the back wall of the unit, using the 5/16-inch socket or nut driver.
Reattach the the fan motor wires by clipping them back into the quick-connect mechanism, and set the wires back into their retaining clips in the same manner as they were attached.
Set the evaporator assembly cover back into place, then reach behind and connect the electrical connection into the wiring harness.
Secure the Phillips screws that hold the evaporator cover to the freezer wall.
Replace the shelves and crisper compartments if they were removed, then plug the refrigerator into its power source and verify proper operation.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Refrigerators
What does an Engine Mount Bracket look like on a Dodge Neon 2000?
it has more than one motor mount there is one in front of vehicle lower part by radiator its a bracket that holds the motor mount attached to frame almost in the middle of motor and transmission there is another one in front of engine i holds motor mount to the body of car
Feb 17, 2011 | 2000 Dodge Neon
Motor mount bracket attached to engine looks like a spacer broke and cant find a name or replacement
The motor mount really has no specific name other than motor mount. Its the location of the mount that determines the part that you need. Just call and parts store and tell them the location of the mount and they will usually be able to match something up for you.
Sep 12, 2010 | Chevrolet Malibu Cars & Trucks
Light does not come on in the ceiling fan
"from the ceiling fan we have black, blue, and white. On the mounting bracket is green. We installed black and blue from the fan motor to the black in the ceiling."
If your fan is working and the light isn't and they are tied to the same wire (black wire), then you might have a bad pull chain switch or bulb.
Feb 18, 2010 | Hampton Bay 56 In. Florentine IV, Brushed...
I have a Kenroy International ceiling fan
Fixya does not sell replacement brackets.
Aug 07, 2017 | Dryers
Cover does not attach to the universal bracket I purchased
Buy a drill and drill bit and make a hole in the bracket where needed. To make installation easier, use a larger that needed drill bit and add washer to screw, won't look as professional but you are not a professional anyway. Who goes around looking at ceiling fan mounts anyway???
Jan 13, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Fan Parts Hunter Fan Type C Model 25436 No. 017626
Cool Breezes Cool Breezes carries parts for old fans that Hunter no longer carries parts for COOL BREEZES 1335 W Campbell RdRichardson, TX 75080
(972) 690-4580push2talk //-->
Sep 18, 2008 | Dryers
Aloha breeze 52 white ceiling fan
Is there something specific you need to know?
Kill power at the breaker for saftey. Mount the bracket to the ceiling first. there should be a small hook on the ceiling bracket that you can hang the fan motor from while you do the wiring.
The blue wire and black wire on the fan should both be connected to the black wire in your house wiring. Attach the fan blades to the motor once it is in place.
Aug 02, 2008 | Aloha Housewares (93645) Ceiling Fan
Hunter 20347 Ceiling Fan Logo
100 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
