A/c chargeing where do you charge the a/c on a 1989 ford bronco
  • 11,896 Answers
There should be a little valve that looks like a tire valve on the refrigerant line. This is the nozzle to fill with R12
Posted on Jul 29, 2009
1989 ford bronco C6 transmission leaking fluid at manual shaft
I have a 1989 Ford Bronco 351 w with a C-6 Transmission. I just did a transmission service, replacing the gasket and filter. Now my transmission is leaking when the bronco sits for a few days.Help!!!
Aug 08, 2012 | Ford Bronco Cars & Trucks
My battery and altenator keep goind dead what is my problem
Replace the alternator. If it is not putting out a charge it will continue to drain the battery while running after fully charging the battery.
Feb 06, 2011 | 1989 Ford Bronco
Air conditioner is blowing hot air. what may be the problem
Your A/C system needs re-charged with refrigerant.
Oct 19, 2010 | 1989 Ford Bronco II
1986 fORD BRONCO, WASN'T CHARGING CHANGED THE
1. get the battery tested to rule out a collapsed cell.
2. If the battery is ok, check the wiring harness that runs from the passengers front corner, to the drivers front corner, for a break in the wires. A common spot to find one would be near the passengers side.
Sep 13, 2009 | 1986 Ford Bronco
Where to charge your a/c
You should see lines comming out of the compressor. follow them around untill you see a black or blue plastic cap that will be the system service port's you need to find out what is in the system from the factory before putting any in.I belive the 1989 fords had R12 and you need to get the system evacuated before getting a R134 retrofit kit to put R134 in it. unless you are certified to work on R12 systems. than you can buy R12 reclaimed ref. but the avrage person can not.
Jul 29, 2009 | Heating & Cooling
Timing setting for a 1989 ford bronco
10 degress before top dead center
Jun 17, 2009 | 1989 Ford Bronco
Firing order for 1989 full size ford bronco 302
13726548 #1 cyl is front pass side and count to back 1234 are on pass side.5678 are on driver side.# 5 being front
Apr 22, 2009 | 1989 Ford Bronco
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
