Question about Durabrand DUR7 Portable DVD Player
Skipping My portable dvd player is skipping when i put a dvd in in the dvd is new and the dvd player is sitting on the table.
  • sverre_helge Apr 24, 2009
    I have TWO DVD/CD players, Samsung and LG. Looking inside reveals both are quality units. But one skips tracks all the time when playing music CD's, but plays DVD's seemingly ok, the other one refuses to 'see' a DVD/CD disc of any kind! My experience of the seller's repair work under guarentee is abysimal, not worth the agro. So I've tried to check things myself. I've re-oiled the laser-carriages etc., but no apparent faults are visible. I suspect a faulty soldered-joint somewhere, but finding it is cost-prohibitive, both for the manufacturers and me. They should check their electronic-boards more thoroughly before assembling them, check their finished products more thoroughly. I cannot save my old VCR tapes to DVD as the DVD is flawed. I'm going to try to connect my old VCR (Nokia, perfect performance) to a burnable DVD, my Mac computer perhaps, via a scart (DIA connection?) Never again will I buy an expensive DVD/VCR. I now use an el-cheapo Philips DVD for 50 Bucks, both as a DVD and a music CD... and it works and sounds perfectly. Never again.... My old VCR tapes will just have to last.
    Novelist:
    Champion:
  • 244 Answers
Skipping
Remove and replace the graphite grease from the laser transport worm gear assembly (use the correct Technics stuff), replace the worm gear drive belt, and ensure that the tension spring on the C-shaped plastic piece that rides the gear is OK
Posted on Nov 24, 2007
Tip
I have a durabrand portable dvd player and all it dose is skip i'm playing...
One fix to return DVD player to origional setings, is to go in to the menu and find the factory reset option the will return the setings back to fresh from the factory.
Regards Tech Guy
on Jul 27, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
Dvds keep skipping
It is possible that your portable set has a defective optical head and so does not read properly the cds. Hence it will be good if you cna get the optical head changed provided the cost if effective. the unit has to be changed with precaution because any static damage to the new head can be serious. hence if you are not familiar get help to install the new head . Hope you try. Good day
Jul 28, 2010 | Toshiba SDP-1800 Portable DVD Player with...
Philips DCP851 Portable DVD Player
We did that too and since the DVD portion was pretty much useless anyway, we 'bounced' the machine (lift the corner an inch or so and drop it) just a little where it was sitting and it finally gave up the discs. It seems to have been the death knoll for the DVD player, however. The tray will open and close but the machine won't always load the disc and play. Sometimes, it does, sometimes not. It also skips now sometimes, but not on every disc. It didn't bother the VCR portion, though. Our DVD player had been used A LOT so it might all be a coincidence that it's acting this way now, but I think putting the two discs in together damaged the inner workings (the bounce didn't help either but it was a loss anyway if it wouldn't open up) so it's up to you whether you want to risk this 'fix' or take it and have it repaired professionally.
Jan 23, 2010 | Philips DCP851 Portable DVD Player
No longer loading dvds
You may have a bad laser. First, make sure the laser assy. travels back and forth easily, then make sure the table the disc sits on spins freely. If it still isn't reading, load a disc and immediatly flip it over to it's top and see if it works. Working or not, still a bad laser.
Feb 12, 2009 | Audiovox D1708 Portable DVD Player
Disc skips when watching my DVD
If you switched DVDs and you plugged it into an electrical outlet and it is still happening, you should take it in to have someone look at it.
Jun 17, 2008 | Polaroid PDM-0082 Portable DVD Player
DVD'S SKIP
Open the top cover and remove the laser housing cover. You should see what looks like a door-hole peeper which is the top lens on the laser itself. Using a "lightly" windex coated Q-Tip carefully clean off the top area of the lens and put the covers back on...
If the unit still skips then it's probably time for a new pick-up table and it will require a bit more testing in the shop to determine the failure.
Hope this helps!
Bill
Nov 13, 2007 | GoVideo DVR4200 DVD Player/VCR
Portable dvd player problem
your lens need to be replace or adjust have a tech look at it.good luck.
Jun 04, 2007 | Durabrand DUR-1700 Portable DVD Player
Durabrand DUR7 Portable DVD Player Logo
224 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
