Question about Garden
Can't get bolts loose on mower blades
On a T1570 lawn tractor with an RCK40LTB deck, are the bolts to hold the blades on left handed or Right handed?
  • termitehocke Jul 30, 2009
    mnfisherman: You don't specify whether that is to tighten or loosen!
  • 11,896 Answers
The bolts that hold the blade need to be turned clockwise.
The bolts holding on the deck need to be turned counter clockwise
Posted on Jul 29, 2009
  • Nate Stansfield
    Nate Stansfield Jul 30, 2009
    On the blades, block blade with wood block, turn clockwise to loosen
    On body, turn counter-clockwise to loosen.
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
How do you check to see if Drive pulley bearings are bad
take belt off, grab blade at end and watch center bolt move more than a little bit or swing by itself when turned loose. Try turn blade with hand to feel bearing roughest is another way
Jul 13, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Blade loose cannot get spindle off
Sounds like you should remove the deck, flip it upside down and use the blade to hold the spindle while you remove the bolt. if its still too hard to remove, spray it with wd40 or liquid wrench and wait a while and try it again.
Jun 08, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motion drive belt shredded. what direction do I turn the pulley bolt on the bottom of the crankshaft under the engine?
It is normally threaded, which is to say it has right hand threads. So you will need to turn left to loosen. You can take a block of wood to brace the blade or use vice grip pliers to block the blade. The blade needs to be immobilized to loosen the bolt.
If this is really helpful for you, please rate four thumbs up.
Jul 18, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How do i lock blade so i can un screw the bolt. I need to resharp the blade
I use a piece of 2x4 . Tip mower onto it's left side, stand 2x4 between deck and blade and remove bolt. You will need to use your leg to keep mower from rolling back. This is just a simple and inexpensive way. You may also buy a special tool to hold the blade while you remove the bolt.
GOOD LUCK>
Jun 12, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Ihave an old john deere lawn mower 21 inch #GX1458. Is the blade screw left or right hand thread
Always unscrew the bolt in the same direction of blade travel.If the blade travels clockwise,loosen bolt by going clockwise.
Mar 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
Sep 03, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
