Question about Konica Minolta Office Equipment & Supplies
EP1081 blank pages-- I started to get blank pages but the empty toner light never came on. I checked the bottle and it was empty so I replaced it but still got blank pages. I pushed the replenish toner button about 15 times and finally got pages but today they are blank again. I have a meter count of 68,717. Do you think I need a new part like a drum?
  • Konica Minolta Master
  • 6,161 Answers
Yes, Drum, starter/developler, and or transfer/seperation corna wires.
Posted on Jul 30, 2009
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
Fix an error message on the Ricoh Aficio 1224c that says 'used toner bottle full'? We have emptied the used toner bottle but the error message persists. What is the best way to fix this?
Check the waste bottle to see if there is a chip mounted on it somewhere. If not see if there is an optical sensor or clear window. If there is a chip it will need to be replaced or a new unit used. If there is a window or optical sensor you should be able to remove it, clean it out, and replace it. These are often the last part to fill with toner and create a light path block.
Feb 06, 2015 | Ricoh Office Equipment & Supplies
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Canon 2220i imagerunner how do you empty the waste toner container
Hello autumn,
Lets start with a reference,which will be standing in front of the copier. Ok,using this reference the waste toner bottle is located on the left side of the copier at the the lowest point of the left side almost at the back of the copier. If you have a stapler/finsher you will need to un-dock it from the copier and slide it away as far as possible, It need not be removed. Now you will have located a cover with one screw. Remove the screw and remove the cover.You now see the bottle.It has a handle so slide it out being careful not to spill it. You can of course pour the waste toner into a strong plastic bag,taking whatever cautions you see fit as you have one hell of a potential mess if not handled carefully.Once the bottle is empty, please notice the neck of the bottle. The way the copier "knows" the bottle is full is by sending a beem of infrared light thru the neck of the bottle. When the waste toner fills the bottle to the neck and blocks the beam of light the copier knows the bottle is full. My point is make sure you clean the neck of the waste toner bottle (if you look closely you will see the "windows" the light travels thru) by using a Q Tip or tissue. If the "windows" are clouded the copier will think the bottle is still full even though the bottle is empty. Does that make sense? In other words you could put a brand new waste toner bottle in the copier with black tape around the neck of the bottle and the copier would say the bottle is full.So now that its empty, and the neck is clean, replace the bottle and the cover.Turn off the "main power switch" located on the right side towards the rear of the copier.Wait a sec, turn it back on and you should be in good shape.Take care and let "FIXYA " know if I helped please. SPINAL
Feb 15, 2011 | Canon imageRUNNER 2220i Grayscale Copier
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
Jan 22, 2011 | Ricoh CL4000DN Laser Printer
Sharp al1631 copier, copys are too Dim settings don't help ?
Check the toner supply, it may be running out of toner. Check the bottle or cartridge for correct install. Turn the machine on and let it warm up, Recheck the copy quality. If it is still light run a dozen blank copies, then a test copy if it is improving the toner is depleted and need to catch up, if it isn't there may be a problem with the toner add system.
Hope this is of some help.
Ed
Apr 27, 2009 | Sharp AL 1631 Copier
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
Waste toner disposal procedure
It's not recommended to empty this as it contains 4 colored toners and you would heve to ensure that the light sensor sees completely clear in the view area. Replace the bottle with type 155 waste toner bottle (about $25) from on line supplier. To do this is simply a matter of opening the right side cover and sliding the green lock lever to the unlock position. Then remove the bottle and replace. Don't forget to slide the green lock lever to the lock position and close the cover.
Nov 18, 2008 | Ricoh Aficio CL2000 Laser Printer
Blank pages after installing new drum
when replacing the toner did you remove the plastic film sealing the toner? if the drums receives no toner you will get blank pages. please check
hope this helps
good luck
Oct 25, 2007 | Brother HL-2040 Laser Printer
Screen Warnings
It means the waste toner bottle is nearly full and needs replacing soon. Here is the link to the printer support page; http://printer.konicaminolta.com/support/current_printers/mc5430dl_sup.htm#DOC Download the user manual/guide. Check page 65 of the manual (page 73 of the pdf file) for instructions on how to replace. Be aware of the safety instructions - toner is very toxic. It is not worth trying to empty the bottle rather than replace it, and most likely illegal. Hope this helps :)
Aug 28, 2007 | Konica Minolta magicolor 5430 DL Laser...
88 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
