Question about Dell Latitude D600 Notebook
My laptop hisses
I have a 5 year old dell laptop. just today it started to buzz or hiss. what is this? how can i make it stop?
  • jalepe914 Jul 30, 2009
    I dont know. i dont think so because it still keeps buzzing when the fan shuts off. its a dull buzz. i just worry it will blow up or something.
  • avalanche434 May 11, 2010
    is it the fan?
  • 57 Answers
Is the sound coming from the speakers or elseware? Mechanical problems could be with the cooling fan, hard drive or a disk in the cd/dvd drive
Posted on Jul 29, 2009
  • Bobcatflusa Jul 30, 2009
    Is it coming from the speakers? Plug in some headphones and check.
Hiss works but
HISS light doesn't work - Honda Motorcycles - FireBlades.org
www.fireblades.org/forums/honda.../37057-hiss-light-doesnt-work.html
May 31, 2005 - 8 posts - ‎5 authors
Is there some setting to make it off/on like the fuel consumption meter has? JakeT. ...This will enable the hiss light. You must turn off the ignition ... 1999 F4 with HISS
Aug 7, 2013
H.I.S.S stopped blinking when 954 is turned off
Sep 10, 2008
HONDA CBR 1000RR 2007 HISS PROBLEMS
Oct 1, 2007
HISS system
Aug 29, 2007
More results from www.fireblades.org
Nov 18, 2015 | Honda Motorcycles
I have old Ingersoll Rand compressor type 30 model 15T serial # 243496 Blow fuss when restart ?
Probably a faulty non return check valve, when the unit reaches pressure air in the delivery pipe is vented down at the pressure switch. If the check valve is passing back this will cause the unit to try to start against a pressure causing it to pull high amps and trip. If there is a constant hiss coming from the pressure switch when the unit stops it will be the non return valve. There should be a short hiss of air when units stops If there is no hiss at all when the unit stops it could be a faulty pressure switch. If it is a quick fix would be to create a small leak on the delivery pipe to vent the line down.
May 28, 2014 | Ingersoll Rand - Rand Type - 30...
Hissing sound from refrigerator after water filter changed (Kenmore, side b side, 4 years old)
Mabe there's some air in the line. Let the water run a bit and see if the hiss stops.
May 24, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Sony STR-DE135 receiver emitting a persistent hissing sound on all functions and inputs (CD, Tuner, TV/Sat, MD/Tape, Video). I have a pair of Boston Acoustic CR5 speakers attached. Any ideas on...
most hissing problems come from earth issues within the system them selves, i dont recommend taking the case of and plugin it in to start testing if its an earth problem. So my best solution is to simply take it your local music or electrical shop and pay for a repair or see id they can diagnose the issue, other than that i dont have a solution for you. I have a little guitar amp which was buzzing it's little heart out, but when i touched my guitar strings the buzzing stops (as i become the earth on touching it) so i tried my guitar on a different amp and it was fine, so my little amp was the problem, i took it apart and noticed that the screw for the earth was loose, once i tightened it the problem stopped and all is good. best regards.
Oct 30, 2013 | Sony STR-DE135 Receiver
Hissing brakes
IT is probably a vacuum leak in the brake booster. With the pedal going to the floor There is either no brake fluid or you will have to bleed the system. Replace the booster and bleed the brakes starting at the longest line first
Oct 08, 2013 | Dodge Neon Cars & Trucks
Loud hissing noise when I play a DVD
maybe the motor spindle are about to crash
Sep 19, 2012 | Philips DVP3150
Sanyo 25" 10yr old model
is the sound like hissing or like a spark something like?hissing can caused by leaking of high voltage that is dangerous and sould be fix right away
Jul 13, 2011 | Sanyo DS25390 TV
Hissing sound from a Panasonic old TV...Sound and picture are OK. The hissing sound even continues when the MUTE on the Box is ON. The hissing only stops when the MUTE on the TV is ON. I am using the...
If you disconnect or power off the converter box does the hiss go away?
If you connect a VCR or DVD player does it still have the hiss? We
need to isolate what source is causing the hiss if it is from the set or
if it is from the converter box.
When you turn the volume control down on the set, does the hiss
reduce in level? If mute stops it, it should reduce in level as you
turn the volume down. Then turn up the sound level control on
the converter box whether its a manual control or by remote. If you
can get a combination that minimizes the hiss and gets higher sound
level from the programming that may cure it.
I am not familiar with the converter box you are using. Are you using
Audio/Video cables from it to the set or is it coming out with coaxial cable
and used on a channel? If you are using a very old set with a tuner input
perhaps the fine tuning is out of adjustment.
Feb 21, 2009 | Panasonic CT-20D11 20" TV
Monitor won't turn on.
Does the cord plug directly from the wall into the monitor, or is there a power "brick" adapter between?
If there's a "brick" listen to see if the hissing is coming from the monitor itself or the brick. If the hissing is coming from the brick you may just need a new power adapter.
If there's no brick or the hissing is coming from the monitor, the monitor probably needs repair. With the price of LCD monitors these days compared to the price of labor, you're probably better off getting a new LCD monitor. Just make sure you take your old one to a proper E-Waste facility so it doesn't pollute the environment.
Apr 05, 2008 | Gateway FPD1760 17" LCD Monitor
Dell Latitude D600 Notebook Logo
132 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
