Where to charge your a/c
Where do you charge your a/c on a 1989 ford bronco?
  • 25 Answers
You should see lines comming out of the compressor. follow them around untill you see a black or blue plastic cap that will be the system service port's you need to find out what is in the system from the factory before putting any in.I belive the 1989 fords had R12 and you need to get the system evacuated before getting a R134 retrofit kit to put R134 in it. unless you are certified to work on R12 systems. than you can buy R12 reclaimed ref. but the avrage person can not.
Posted on Jul 31, 2009
How to trouble fuel pump on 1989 bronco 2
o.k. check the fuse also the fuel pump relay you can download the manual in there is the fuse diagram go to 1989 ford bronco owners manual from ford it's free and can be put on your phone or you can print it this will help it also could be a broken wire or dirty connection
Feb 19, 2015 | 1989 Ford Bronco II
Wireing ford 89 bronco 2 solenoi setup
I've had this problem. I replaced the battery cables and ends and solved my problem.
May 02, 2014 | 1989 Ford Bronco II
1989 ford bronco C6 transmission leaking fluid at manual shaft
I have a 1989 Ford Bronco 351 w with a C-6 Transmission. I just did a transmission service, replacing the gasket and filter. Now my transmission is leaking when the bronco sits for a few days.Help!!!
Aug 08, 2012 | Ford Bronco Cars & Trucks
1989 Bronco: 89 ford bronco i put a new starter new battery new...
Check the battery cables for corrosion near the battery terminal end. Sometimes it builds up under the rubber insulation. I would check the ground wire that runs from the battery to the engine block.
May 16, 2010 | 1989 Ford Bronco
Does a torque converter for a 1989 ford bronco trwo have antyhing to do with a fly wheel
The torque converter bolts to the flex plate at the rear of the engine. It supplies the link between the engine to the transmission.
It's known as a "Flex Plate" and not a "Fly Wheel". The flywheel is use on a standard transmission.
May 14, 2010 | 1989 Ford Bronco II
Timing setting for a 1989 ford bronco
10 degress before top dead center
Jun 17, 2009 | 1989 Ford Bronco
Firing order for 1989 full size ford bronco 302
13726548 #1 cyl is front pass side and count to back 1234 are on pass side.5678 are on driver side.# 5 being front
Apr 22, 2009 | 1989 Ford Bronco
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
