SOURCE: Fan noise in freezer of my GE side-by-side refridgerator
You don't have to worry about the ice and frost, Your heater does that for you Your heater comes on and defrost every day. You just need to tighten the screws and clean up the vent where the noise is coming from but I wouldn't worry about it. The temperature on your fridge and freezer is running optimal, You know the saying, if it ain't broke, don't try to fix it....just tap the vent covers every few days.
SOURCE: loud squealing noise
The noise is most likely the serpentine belt. Check it's condition and that of the belt tensioner. It sounds like the belt is slipping, causing the squealing noise u describe. As the belt warms up, it's getting a better 'grip' and the noise stops. Turning on the heat also turns on the a/c in newer cars, this added drag on the belt (one more component to turn, the a/c compressor) would explain why it happens when u turn on the heat. Is the belt original? If yes, it's time to change it, and check the belt tensioner to make sure it's doing it's job of keeping the belt snug on all the pulleys. Let me know how u make out.
SOURCE: when engine fan engages makes loud squealing noise
OK, the motor that you are referring to has lots of cooper windings and internal parts that can become misaligned during long term operations and extreme heat situations. this noise you are hearing is basically a warning sign that is trying to tell you that this motor is failing and will go out soon.
SOURCE: squealing noise coming from the belts while engine is running
take off your serp-belt and spin your water pump, alternator, idler pully and see what squeaks or feels rough. your water pump bearings may be bad. the only thing you can do is change it. dont forget to change your thermostat and antifreeze. FYI your antifreeze is made with lubricants in it for your water pump bearings.
Usually when the fan in the freezer is making noise it is because there is ice built up and it is hitting the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
