Transmitter stopped working, when the sound system is turned off it doesn't turn off.
    President:
  • 2,559 Answers
Have you replaced the batteries?
If so,it may need reprogrammed.
Posted on Jul 30, 2009
My alarm system went off due to wrong key ingnition...had to take a battery terminal off to stop the alarm, now I have the key and it wont start...is there a security reset?
Yes there is. 1. Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming. 2. Turn ignition to run position. (Allow ignition chimes to stop).
3. Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6. Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
Aug 15, 2011 | 2002 Jeep Liberty
Does anyone know how to turn off the "Valet Mode" on a 98 Jaguar XJ8L? We can't get the trunk open. Every time we try to open it, we get a message on the instrument panel - "In Valet...
sounds like you have 2 probs if you turn ign on whilst holding valet button pressed it should cancel it if not the key is poss faulty
Apr 18, 2017 | 1998 Jaguar XJ8L
I LOST MY CHEROKEE CONTROL REMOTE ALARM, I BOUGHT A NEW ONE BUT ITS NOT PROGRAMMED AND I WOULD LIKE TO HAVE SOME HELP TO SOLVE THIS PROBLEM. CAN YOU TELL ME HOW TO PROGRAM IT. IT IS A CHEROKEE LAREDO...
NOTE :PLEASE READ INSTRUCTIONS FULLY BEFORE ATTEMPTING TO PROGRAM TRANSMITTERS.
Program Method A (Customer Program Method)
NOTE :(FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP # 6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
7. Repeat steps 5 through 6 to program additional transmitters.
8. Turn ignition to OFF position. Transmitter programming mode v/ill discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
Program Method B (Customer Program Method)
1. Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
2. Turn ignition to the run position (Allow ignition chimes to stop).
3. Using original transmitter, press and hold the [UNLOCK] button on the transmitter for between 4 and 10 seconds.
4. Continue to hold the [UNLOCK] button and press the [PANIC] button. A chime will sound to indicate that the transmitter programming mode has been entered (Allow 3 seconds for chime to sound).
5. Press a button on all transmitters to be programmed into the system including any previously programmed transmitters; a chime will sound when each transmitter has been programmed.
6. Turn the ignition to OFF position to exit the transmitter programming mode.
Program Method C (Dealer Program Method) *Can be used for any type transmitter.
3. Plug DRBIII to vehicle's 1-way data link connector.
4. Follow Service Manual and DRBIII instructions to program transmitters.
Program Method D (For use with AB vehicles not equipped with VTSS only)
1. Locate the dark green program enable wire connected to pin # 1 of the 16-way data link connector under the left side of the instrument panel.
2. Connect the program enable wire terminal to a good ground.
3. Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.
4. Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.
5. Repeat step 4 to program additional transmitter.
6. Disconnect the program enable wire from ground to exit program mode.
7. Turn the ignition to the OFF position and remove the key.
NOTE :REFER TO DAIMLERCHRYSLER MDS2 SYSTEM OR PARTS DEPARTMENT TO OBTAIN THE CORRECT PART NUMBER AND REVISION FOR SPECIFIED VEHICLE.
Dec 18, 2010 | 2002 Jeep Grand Cherokee
Program keless entry for 2005 dodge ram 1500 slt 4.9l engine
ATTENTION: You MUST HAVE one working remote to add one more to the system. If you do not have one working remote right now then these instructions will not work. You will have to have a Locksmith or dealership use a computer to program the first remote for you.
1. Turn ignition to the RUN position (as far as you can go without starting the engine).
Wait for chimes to stop.
2. Using original programmed remote, press and hold the UNLOCK button on the
remote for between 5 and 10 seconds.
3. While holding UNLOCK button, and before 10 seconds passes, press and release
the
PANIC button. A chime will sound to indicate that the transmitter programming
4. Within 30 seconds of the chime, press a button on all remotes to be programmed
into the system including any previously programmed remotes, a chime will
sound after each remote has been programmed.
5. Turn the ignition OFF to exit the transmitter programming mode.
6. Test Remotes
Apr 26, 2010 | 2005 Dodge Ram 1500
I bought a used 2005 dodge ram and the only keyless remote I have does not work. I have already replaced the battery. Can I re/program this remote myself? If so how?
the
mode
has been entered.
6. Test Remotes
Jan 08, 2010 | Alarm & Keyless Entry System Dodge...
Reprogram 2005 dodge durango key fob
Daimier Chrysler North American Remote Keyless Entry Programming procedures
1. Press (LOCK) button 5 times at 2 second Intervals to resynchronize transmitter, Attempt to function transmitter, If working as designed discontinue programming.
2. Turn ignition to run position, (Allow Ignition chimes to stop).
3. Using any original (working )transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to l0 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
6. Press and release any button an the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
NOTE.- (FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP #6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
8. Turn ignition to OF:F position. Transmitter programming mode will discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
Nov 05, 2009 | 2005 Dodge Durango
1999 Chrysler Town and Country
Have you you tried just re-programming all of your remotes? I just added a "new" (from Ebay) remote and when re-programming, had to do them all. Here's how... 1. Using a functional key fob transmitter, unlock the vehicle and disarm the Vehicle Theft Security System. 2. Insert ignition key into the ignition switch. 3. Turn the ignition switch to RUN position without starting engine. 4. Using a functional key fob transmitter, press and hold the UNLOCK button for a minimum four seconds (maximum ten seconds) 5. While holding UNLOCK button, and before ten seconds passes, press and release the PANIC button. A single chime will sound to verify that the RKE module is set to receive the new Vehicle Access Code(s) 6. Within 30 seconds of the chime, press and release the "LOCK" and "UNLOCK" buttons on the transmitter at the same time. Then press any one of the buttons. The BCM will sound an abbreviated chime to acknowledge that the programming of the transmitter has been completed and was successful. 7. Repeat step 6 for all transmitters that will be used with this vehicle (up to 4 total) 8. Programming mode will last for 30 seconds. To get out of programming mode sooner, turn the ignition OFF. A single chime will sound to verify that the RKE module will no longer accept additional Vehicle Access Code(s) 9. When Vehicle Access Code(s) programming is complete, turn the ignition switch to the OFF position and verify RKE system operation using each key fob
Aug 03, 2009 | 1999 Chrysler Town & Country
No sound coming through my Sennheiser wireless headphones
Turning the transmitter on and off (Fig. 5)
Turn on the sound source. This automatically activates the
transmitter and the green LED “ON/OFF” lights up. If the sound
source is turned off, the transmitter is automatically deactivated
after approx. 3 minutes (the LED “ON/OFF” goes off).
Note: The automatic level control only functions if the volume of the
sound source is sufficient.
Mar 03, 2009 | Sennheiser HDR 140 Consumer Headphones
No sound from rear speakers on the lifestyle 18
The SL2 works in such a way that the speaker satellite out put from the bass modules is fed to the input of the SL2 transmitter (remember, transmitter) then the sattellitespeakers are connected at the other end of the room to the receiver. An initial blinking green light should be seen and once the system is turned on this turns into steady green. Both the SL2 transmitter and receiver operates via WIFI.
Glad to be of service...
Dec 21, 2008 | Bose Lifestyle 18 System
Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Dec 16, 2008 | Sennheiser RS 120 Consumer Headphones
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
