Question about Dyson Vacuums
My Dyson Vacuum DC24 suction loss.
I've done all the recommended steps of cleaning filters & clear blockages yet the suction remains pathetically weak. I've even cleaned the seals & it didn't help much. The suction loss effects both the hose & floor head but the hose has even less suction power than the floor head even after checking for blockages.
    Master:
  • 691 Answers
You sound pretty savvy in your troubleshooting. Take a look at this video. You may have a split in one of your three suction hoses. I tried to find a video for a DC24 but to no avail. These two models are pretty close and this video should help you out.
Posted on Dec 04, 2017
Testimonial: "I checked the seals for tears but not the hoses haha THANKYOU very helpful, I really appreciate it :)"
5 Suggested Answers
chris321918
  • 32 Answers
SOURCE: vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Posted on Jan 19, 2009
SOURCE: Dyson DC08
i managed to take the cyclone apart. here is some help with what i did I hope this helps. You will need a philips and torx screw drivers. Especially torx with T - handles and thin shaft makes the task much faster and easier.
1. first undo the screws holding the top handle.
2. lift that part of the handle and pull towards the other end of the handle at the same time. Care this is a tricky manoeuvre but the other end is just sloted in. sometimes may be glued so some force may be needed. see photo 1
3 Once the handle is off. there will be screw under the end that you pulled off. undo that screw. see photo 57bd18a.jpg
4. Now turn the cyclone upside down. Pull the cone off. this is only a push fit and should pull off
5. Now you should be able to see the three torx screws holes as indicated in the photo.38c6322.jpg
6 The removal of these torx will enable this section to be pulled off exposing one more layer with three further torx screws to be removed as indicated in the next photo7a60cdc.jpg
7 Once the final torx screws are removed, turn the cyclone upright and the top bit which held the handle should come off exposing the complex combe structure. see photo 92fa764.jpg
8 Then you should be able to lift the combe structure as well see photo 349cdfc.jpg
10. Thoroughly was all the parts with water and make ABSOLUTLY sure that the part are dry before putting it altogather again. Your vacuum will be as good as new. mine was. good luck and happy cleaning.
Posted on Apr 11, 2009
SOURCE: My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Posted on Apr 23, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: my dyson DC24 has very poor suction - all filters clean and hoses seem to be clear. had it for just over a year
    I'm sorry to hear your DC24 doesn't seem to be picking up as well as it should be. From your description of the issue, it sounds as if there may be a blockage in the machine - to locate and remove this, please follow the steps shown in our online Support guide:
    http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
    You may also want to take a look at the video below to make sure you've washed the filters as we recommend. Use cold water without detergent, and allow at least 24 hours for them to dry completely somewhere warm before replacing them. In normal use, this should be done at least once a month.
    I hope this helps - if you'd like any further assistance or advice, please give our customer Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    Posted on Apr 11, 2012
    DC24 loss of suction when upright
    blockage in the yoke or side pipe, remove head, use a finger to feel for the paper thats stuck inside, and remove side pipe to clear from the top of the yoke 5 min fix
    Aug 19, 2017 | Dyson Ball DC24 Bagless Upright Vacuum
    No suction.
    Hi Sandra,
    I am sorry to hear you are having difficulty with your DC24. Generally the problem you described is caused by a blockage or unwashed filters. We have step by step instructions in the support section of our website that will help with this. Please visit the appropriate link below for help locating and removing any blockages and washing your filters.
    US:
    http://www.dyson.com/support/dc24/dc24-multi-floor/diagnosis-root-menu/dc24filterwashvid/dc24filterwashvid
    UK:
    http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/filter-washing-video
    If the recommendations above do not resolve the problem please contact our Helpline to speak with an expert.
    US - 1-866-693-9766 or UK - 0800 298 0298
    Best wishes,
    Jessica
    Dec 22, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
    Rear canister valve
    Hi there Coire, it's Jack at Dyson.
    The valve you've described is the suction relief valve. This will open when something is restricting airflow through the vacuum cleaner.
    In normal use, we recommend washing both filters at least once a month, as shown in the video above. Use cold water without detergent, and allow at least 24 hours for both filters to dry completely somewhere warm before replacing them in the machine.
    If you find this doesn't resolve the issue it's likely your machine has a blockage - to locate and remove this, please follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/check-suction
    For any further advice after you've given this a try, please contact our experts directly by calling the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
    Best wishes,
    Jack
    www.dyson.com
    Nov 09, 2013 | Dyson DC24 Animal Bagless Upright Vacuum
    My dyson DC24 has very poor suction - all filters clean and hoses seem to be clear. had it for just over a year
    Best wishes,
    Jack
    Apr 10, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    Dyson dc24 no suction at head of cleaner, the hose has good suction and the brushes are not spinning
    Hi Janice,
    If your machine has no suction from the cleaner head, I'd recommend that you check the machine for blockages and reset the brushbar. To locate and remove any blockages, please follow the steps shown in our online Support guide:
    To reset the brushbar, please follow the steps shown in the video below. The brushbar will not rotate when the machine is standing upright, so please recline it into the vacuuming position before testing it.
    This should resolve the issue, but if you need any assistance locating the blockage, please call our Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
    Best wishes,
    Jack
    Mar 27, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
    Suction in hose okay through floor piece not working
    I'm sorry to hear you're having difficulties with your DC24. From what you've described, it sounds as if the suction relief valve is activating - this is likely to be due to a blockage in the machine, or because the filters need washing.
    The easiest way to locate and remove any blockages is to follow the simple steps shown in our online support guide:
    http://www.dyson.com/support/help.asp?article=1120&product=DC24-ALLFLOORS
    DC24 has two filters, both of which need washing at least once a month, as shown in the video below. Use cold water without detergent, and allow at least 24 hours for them to dry completely before replacing them.
    I'm confident that following these steps will resolve your issue. However, if you'd like any further assistance, call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Nov 13, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    No suction when using hose attachment
    Hi there, I'm sorry to hear you're having difficulties with your DC24. If suction through the hose doesn't seem to be as strong as usual, you may have a blockage in the cleaner. I'd also recommend giving the filters a wash. The easiest way to locate and remove any blockages is to follow the steps shown in our online support guide: http://www.dyson.co.uk/support/help.asp?article=1492&product=DC24-ALLFLOORS The correct way to wash the filter is shown in the video below - under normal use, this should be done at least once a month. Use cold water without detergent, and allow up to 24 hours for the filters to dry completely before replacing them. Following these steps should allow you to resolve your issue without further assistance. If you have any other questions about using or maintaining your Dyson cleaner, please get in touch with us directly by calling free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Kind regards, Jack Dyson Online Customer Support
    Sep 12, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    My dyson has, against all it's proclamations, lost suction. I clean the filter regularly (wash it out, etc) - I replaced the hose (it had a hold in it). Any thoughts?
    Sorry to hear you're having difficulties with your DC24. If it doesn't seem to be picking up as well as usual, and you've already washed the filters, it's likely that there's a blockage somewhere in the cleaner. The easiest way to check for and remove any blockages is to follow the steps shown in our online support guide:
    You might also want to take a look at the video below to confirm you're washing the filters correctly. Under normal use, it's important to wash both filters at least once every month. Use cold water without any detergents, and ensure the filters are totally dry before replacing them - this may take up to 24 hours.
    Hopefully, by clearing any obstructions and washing the filters, you should be able to resolve your issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you recommend the best course of action.
    Kind regards,
    Jack
    Aug 23, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    No suction coming from the wand
    Sorry to hear you're having difficulties with your DC24. If there's no suction from the wand, you may have a blockage in the wand or hose. The easiest way to check for and remove any obstructions in the cleaner is to follow the steps shown in our online support guide:
    By clearing any blockages, you should be able to resolve your issue. However, if you've followed the steps shown above and are still concerned, please get in touch with us directly. One of our experts will be happy to run through some troubleshooting checks over the phone with you, and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
    Kind regards,
    Jack
    Dyson Customer Service
    Aug 07, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
    Loss of suction and only 10months old. I,ve cleaned out cylinder but it is making a noise when first switched on like its blocked somewhere? and not picking up
    Sorry to hear you're experiencing a problem with your DC07. From what you've described, it sounds like you may have a blockage somewhere in the machine. We would also recommend washing the filter - this should be done every 3-6 months.
    You may find the Support section of our website helpful in showing you how to wash the filter, and how to locate and remove any blockages from the system:
    http://www.dyson.co.uk/support/help.asp?article=1940&product=DC07-ANIMAL
    If you've followed these steps and are still experiencing difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
    Kind regards,
    Jack
    May 08, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Vacuums Logo
    82 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Manchester Vacs
    Manchester Vacs
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
