Their is most likely a problem with the pixels in your display. the reason why it dose this is that after the television warms up (about half and hour) the pixels adjust and start to work properly the only fix would be to replace the entire screen
This is what digital signals do if there is not enough signal to paint the picture on your set. If you are using an antenna, then the signal coming from the station over the air is not strong enough or is being blocked by the trees and buildings. The TV needs a signal at least 60-70 % to get the data, and since the FCC mandated higher frequencies for over the air TV, the stations signal will not travel very far. You can try a better TV antenna, with a higher DB gain, but it seems to be a loosing battle for the present.
If you subscribe to cable TV and it is happening, then by all means complain to your Cable Provider as they should send yo a signal that will run your set.
Hi,It sounds like a problem with the color wheel or DMD board. The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will hear ,humming,buzzing,high pitch noises ,you might also experiment color distortion ,black and white picture. This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Hi,do you mean tv is showing an amber picture? If you do,it could be an issue with the color wheel or dmd board.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
1 In any Still mode, press the button repeatedly to choose: 10 seconds?A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds?A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot?The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later. 2 Compose the scene. 3 Press the Shutter button halfway, then completely down.
The problem is lack of bandwith of the receiving signal from your daughter. The Skype server is located in the UK and all video and audio data signals go to and from the Skype UK server before it goes to you and your daughter. This lack of bandwith causes the video image to break up and a delays in audio just like a weak high definition signals to your digital television.
You can see your own video and hear your own audio from your WEB cam clearly, because the video and audio data does not have to go to the UK and back again, also your satillite connection is probably not as fast as a cable broadband connection. Your daughter may also experiencing the same video and audio problems.
Video data contains a lot more information than the audio data. Therefore there are a couple of things you can do to improve the situation :-
Get your daughter to and possible you as well (if she is also experiencing break up of video and audio), to reduce the video image size from 640X480 to 320X240 resolution.
If the video is still a problem then turn off the video all together and only communicate by audio, this will reduce the amount of data being transmitted and should give you a clear/clean audio.
