Question about Kenmore 75085 Air Conditioner
Air conditions trips circuit, wont stay running.
Our air conditioner turns on and about 20min later trips the circuit, after we turn it back on it only stays on for about 5 min, can you help?
  • DYRON REDDICK Jul 30, 2009
    Yes! I can conferm I opened up my air conditioner and cleaned the condenser both on the outside and right infront of the unit fan. and now it burrrs like a kitten.. Thanks.
Is it a window unit?
Did you check that the condensor coil is free of dirt?
Is the Fan motor running or does it stop before the breaker blows?
Posted on Jul 29, 2009
My L.G A/c have problem in power
Outside unit turns on and runs for a long time by itself then shuts off. Does this all day an night long. Notice this after a circuit breaker tripped. Not breaker to unit though. Other parts of house.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other Air Conditioning Repair help. Check us out online.
Jul 25, 2016 | Celiera Celi 24000 BTU Ductless Mini Split...
How do i fix my central air conditioner from tripping the circuit breaker?
tripping circuit breakers indicate shorts in the system or overload from a compressor failure
call in a technician to properly diagnose the problem and get a quote
Jun 01, 2016 | Heating & Cooling
Wont turn onwhen i plug in.
the control might be bad or the power board...you will need to check this first.....
Apr 03, 2010 | Goldstar KG6000R Window Air Conditioner
Central AC unit replaced breaker trips after running 20min
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Jul 22, 2009 | Weather King 10AJA6001AH Air Conditioner
MY AIR CONDITIONER TRIPPED ,NOW IT WONT COME BACK
Unplug unit let set till cool then turn on motor has heat trip button that will pop out so it wont over heat, It should pop back in when it cools off. Make sure filter is clean and condenser is not iced over by high humidity. If unit still wont come on check house fuse or breaker it should be on a circuit by it's shelf, flip it off and back on so it is closed all the way.
Jun 27, 2009 | Fedders A6P09S2A Air Conditioner
Roof top air conditioner wont stay on
Clean the condenser could be tripping on high pressure switch or low pressure switch low on freon have leak fixed and recharged. Tom
Jun 13, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Apr 22, 2009 | Dometic Rooftop RV Air Conditioner
Heat pump trips circuit breaker
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Kenmore 75085 Air Conditioner Logo
294 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
