Question about ASUS Eee 4G Notebook
Windows won't star up - ASUS Eee 4G Notebook
  • Nouveau IT, LLC
    Nouveau IT, LLC May 11, 2010
    Hello, Could you tell me more about what you experience when you power on the pc? Thanks C2Solutions
  • anthony allison May 11, 2010
    is it a blue screen with a bunch of paragraphs or is it takeing forever for it to load.or is there a black screen saying boot error.
    Problem Solver:
  • 16 Answers
If some startup foles are corrupted it might not start up. You can download a utility Active boot disk Make a bootable usb with it , then run a check disk on your c drive. If it repairs the bitmap sector your windows should startup
Posted on Jul 30, 2009
97 traspot won star
check the fuse to be sure it's good listen after you turn the key on to see if you can hear your fuel pump run
Oct 01, 2014 | Vehicle Parts & Accessories
Mazda 3 2005 won shift from park and won star either I have to put in neutral to b able to star car?
If it won't shift from park my first question would be how do you get it Into neutral? Sounds like you may have a gear selector sensor issue .
Oct 14, 2013 | 1997 Mazda MPV
V star 950 won't start
Hi, Joe you may have fried the ECM while trying to jump it from the Jeep otherwise the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
VStar 650 won start
Frustrated Yamaha Star Won x27 Start
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
OEM parts for Yamaha
YAMAHA XVS950A Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 31, 2013 | 2011 Yamaha V Star 950
My computer won't boot from the screen asking for a choice to safe star
Do you have A INSTALLATIONDISC.Place it computers cd player.and let Windows start from it.and repair the computer.if no disc try F8 .F10.or DEL depends on computers manufactor.it should have have a partition for repairs.chose startrepair.
Mar 29, 2013 | Computers & Internet
My tilde key won't work
Did you hit the and hold the shift key with it?
Jun 26, 2012 | Global Star Software Airport Tycoon 3 for...
Star Trek: Starfleet Command 3 closing to desktop without warning
Put the spec's of the pc here vid card memory board info, that might help!
Im running soldier of fortune 2 under win10 64bit so it must be possible under xp. Feel free to use this https://steamcommunity.com/sharedfiles/filedetails/?id=837445398
Jan 08, 2018 | Activision Star Trek: Starfleet Command 3...
Yamaha royal star xvz 1300 won't idle without choke
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
2003 Star 1100 Custom won idle without choke aftermarket exhaust
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
https://www.tradebit.com/filedetail.php/243740175-1996-2001-yamaha-royal-star-xvz13a-service-manual
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Jan 01, 2012 | 1996 Yamaha Royal Star XVZ 1300 A
ASUS Eee 4G Notebook Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
