No sound from speakers, a little sound can be heard on earphones so the keys seem to work fine.
SOURCE: Logitech LX310 keyboard / mouse (wireless)
it works fine on my brothers computer but it doesnt work on mine, i dont really want to reformat either. any way of fixing it without reformat?
SOURCE: Roland Juno D Keyboard Keys not sounding
The problem of the Juno-D is de rubber strips inside under the keysthere are 5 strips, you have to clean this rubber strips with alcohol and clean the board too, this will resolve your problem if you leave the Juno-D without playing for a long period you will get the same problem again. this is a very poor keyboard it,s a pitty that Roland Make so poor keyboard!!!!
SOURCE: No sound when piano keys are pushed on my Yamaha dgx-620
I'm sorry but it sounds like you will have to have it repaired professionally.
SOURCE: Edirol PCR-50 wont output any data for most keyboard keys
Yes people it can be fixed
by yourself at home, cheaply and easily. I’ve got an Edirol pcr-80 &
prc-a30. Both have had intermittent key troubles and keys that just don’t work
anymore or low/high level compared to other keys. These problems seem to start
after a year or so. I’ve paid hundreds of dollars getting them fixed until I
tried this on a whim. The contacts under the keys are a carbon-based contact so
cleaning them with metho/alcohol just dries out this carbon. Some people say
cleaning them with a pencil easier helps and it can do slightly but not
properly. What you need is “Graphite Powder”. (Link for a picture of a appropriate
product – just cut and paste it in your Internet heading bar, or Google image search
graphite powder…)
http://images.google.com.au/images?hl=en&source=imghp&biw=1024&bih=1080&q=graphite+powder&gbv=2&aq=f&aqi=g1&aql=&oq=&gs_rfai=
Graphite powder is a dry
fine powder that is conductive and perfect for the job. You can purchase at any
locksmith – maybe a good hardware store, and it is sold as “non liquid
lubricant for locks and machinery.”
All you need to do is unscrew the case, remove the springs
that hold the keys in, remove the keys. (White keys first then black keys. Keep
in order.) Peel off the rubber strip under the keys and turn over so you can
see the little carbon nipples that touch the circuit board. (2 for each key)
Pour a little power out on a sheet of paper and use a cotton tip bud to apply a
little powder to these. Now apply a little to the carbon contacts on the circuit
board where the little nipples touch. Do all this with your midi keyboard
plugged in to your computer/synth etc so you can hear how you’re going with
getting contact before you put it all back together. You might get a key or two
going off when doing this because the graphite power is making a continuous
contact across the circuit board. Just blow/lightly wipe away excess to stop
this but you want to leave all the contact points evenly (if slightly) coated.
Try touching the rubber strip contacts with the circuit board contacts to see
if you can get a sound. This can be a bit tricky to line up and get an even
contact. This sorts its self out when everything is back together.
Now put back the rubber
strip. I used I tiny screwdriver to help push the rubber guide back in the
holes on the circuit board. Now put the keys back (black first – with the short
springs then white keys with the longer springs) screw the case back together
and let me know how you went.
This I think will dry up
again in time but if you get a good bit of use out of it you can just do it
again… For free…
Garthy.
