Question about Gateway MX8711 Notebook
Computer stopped receiving power and won't turn on.
Computer stopped receiving power from the power chord. Died and won't start again. Had this problem with a duplicate computer, the power chord port was loose and finally just died a few weeks ago. Transferred the hard drive into this computer (exactly the same) and now the same thing has happened, minus the loose power chord port. Never had this problem with this computer before.
  • fyrespryt574 Jul 30, 2009
    Everything was exactly the same when we switched it over and it booted up just fine. It worked great for about three days and when we woke up this morning, my husband noticed that it was running on battery power, and then it just died - because the battery was drained. It had apparently been running on battery power for a while. It was plugged in, yet not getting any power. We'd never had any power problems with this computer.
Hi i can fix ur laptop, i have fixed many with this sort of problems, email me at mau5747@hotmail.com.
Posted on Oct 22, 2009
  • Gateway Master
  • 32,281 Answers
When you move the hard drive from one computer, it won't boot up unless the both computers are exactly the same model and configuration and with the same installed devices.
Generally you need to install Windows again to get a functioning computer when you transfer a hard disk into another computer.
Posted on Jul 30, 2009
Speakers not Charging
Make sure the power cord is completely plugged into the back of the speakers. make sure the speakers power button/switch/knob is turned on. if both of these things are not the reason call the company you got them from and ask about a warranty.
Mar 02, 2014 | Brookstone Audio Players & Recorders
I connected my 32" Funai LCD TV to PC CPU with VGA cable. I could watch the movie once. However, not able to get the connection again. TV gives message "Not Support". Do i have to change the settings
Make sure your VGA chord is connected to both TV and Computer. Right click on your desktop and go to screen resolutions. Click on Connect to a Projector and click the Duplicate icon.
Jan 29, 2013 | Televison & Video
When I click on print I get a message in a box that says "printer cannot communicate with computer. The box then has various options that might remedy the problem. These include disconecting the...
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
Mar 28, 2011 | Computers & Internet
My 1995 jeep grand cherokee died while driving,found that computer was bad,replaced,all was well for a day or so,now died again with exact symptoms,was told that a bad sensor may be taking out...
I need to know all the fault codes you have received on testing. I really doubt that any sensor is taking out the computer, worked this type of repair for 20+years and have never seen that happen, not once.
Jun 25, 2017 | 1995 Jeep Grand Cherokee
Laptop Won't Turn On (Toshiba Satellite U205-S5057)
Try a new power adapter before you try the other expensive tests and repairs. The adapters are notorium about failing after being used continuously . If you can check the outgoing voltage at the tip where it fits into the DC jack on the laptop would be good. Match the output to the rated voltage needed to peoperly power the laptop.
Sep 07, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Power unplugs on laptop, black screen, computer still running
It's a common trouble for the power cord from the adapter to break inside the insulation near the plug. This is because of frequent flexing of the cord near the plug. When this happens you'll see the power light on the computer go out, and wiggling the cord sometimes gets it going again. Without the power input, the battery doesn't charge and the laptop won't stay running.
This sounds like what's happening to your computer, and should be fixed by replacing the adapter. Generic replacements are available at reasonable prices from online vendors and at Radio Shack and big computer retailers. It's also possible to repair the adapter by cutting the cord back and soldering on a new plug if you or someone you know has the tools and skills.
Please take a moment to rate this solution if it's what you needed. Thanks for asking here!
Feb 25, 2009 | Computers & Internet
Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
Jun 10, 2008 | IBM ThinkPad T43 Notebook
Emachine problems
Hi..
Since your computer is working but no display at all. Hope this steps would be helpful in your problem.
1. Turn on your computer, If the problem works again and no display.
2.Turn off your computer by pressing long your power botton until the fan stops properly.
3. Unplug you computer 220volts power chord at the back of your computer.
4. Reconnect again the 220volts power chord after 1 minute.
by. arnold@supportsave.com
Jun 04, 2008 | E-Machines eMachines Desktop PC
Gateway mx6920
try to remove your memory then use the eraser to clean up the tip of the memory then put it back try to turn in on
Mar 23, 2008 | Gateway MX6920 Notebook
Gateway MX8711 Notebook Logo
227 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
