Question about Crafts & Hobbies
Where can I find a motherboard for cricut expression to buy to replace mine?
  • 20,407 Answers
This page mentions some parts and links
Cricut Repairs ATXHackerspace
But the best place is going to the maker direct
Official Cricut Help Center
Posted on Dec 03, 2017
  • 9 Answers
SOURCE: need to update firm ware on cricut expression so i can use sure cuts alot could not find at cricut.com
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
balboul@gmail.com
Posted on Jul 05, 2009
CricutAddict
  • 13 Answers
SOURCE: Cricut Expressions Machine error
  1. Make sure your cricut is off when you plug it into your computer via usb.
  2. Make sure your usb cable is plugged directly into the machine, and not to a usb hub.
  3. Start up the DS Once the DS is fully loaded, choose HELP > UPDATE FIRMWARE.
  4. On the cricut machine, hold down the STOP button. Keep holding it down and briefly hold down the power button. Keep holding down the stop button and in about 3-5 seconds, you will hear a beep. That means you are good to go.
  5. On the "update firmware" screen on your computer, select the model you have and then click "begin updating now"
  6. Go and read a magazine or make a cup of tea because it takes a while to update. If it goes really fast (no matter how cool your computer is) it means it did not install properly and you will probably have to do it over again.
Hope this helps you.
Posted on Mar 25, 2010
SOURCE: the cricut expression blades do not cut and I have
melenddia,
Is there a white tape sticking out of the lower back portion of your expression? This sounds like my problem.
Posted on Apr 19, 2010
  • 313 Answers
SOURCE: My Cricut Expression keeps turning on and off.
I have one of these machines stripped down on the bench now with this problem. I have located the fault to a power relay which is sealed but must have burnt contacts as it is not passing the power to the machine to power up. I am still looking for a source of 18 volt coil relays with 10 amp contacts to fix this one. If not I may have to modify the circuit to overcome this problem.
Posted on Jul 25, 2010
tlargent365
  • 6 Answers
SOURCE: I need a manual for a cricut expression
www.manualsonline.com/
Posted on Feb 18, 2012
I have 2 Cricut Expression machines. I want to keep the newest one. How can I tell which one that is
from what i can tell, the cricut expression has dials and the cricut expression 2 has a touch screen. Also, I believe the newest one is a little larger in size.
Oct 22, 2017 | Crafts & Hobbies
Cricut machines power supplies
18 volts is the voltage and the thing that is most critical to stop the machine burning out.
The 'A' - amperage is the force behind the electricity, 2.0 is a sort of fairly strong person 2.5 amps is a muscle man.
If the piece of equipment needs a muscle man to move it and you use a weaker person, it may not move quite so fast. Good analogy?
Anyway, .5 amps is not going to make that much difference.
Jun 26, 2016 | Cricut Expression Cutting Machine
Where I can buy Cricut Expression Roller Bar Endless belt?
I would measure the belt total length and look it up on the web.
Aug 04, 2015 | Cricut Expression Cutting Machine
How can I get a new Encoder board V2Encoder for a Cricut Expression?
You may be able to get a replacement circuit board from the source where you purchased your Cricut Expression. More likely, It will require an inquiry to Provo Craft to determine availability and source.
Feb 02, 2015 | Provo Craft Cricut Expression Personal...
My cricut wont turn on
Hi, My cricut expression is more then 5 years old. I used it one day and the next day I would not come on (it dose Nothing at all). I brought a new power cord from cricut and still nothing. I'm unable to buy a new one Please help if you can. Thanks!!
Jan 26, 2014 | Cricut Expression Cutting Machine
Cricut expression 2 has no power, will not turn on
Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
Nov 05, 2011 | Cricut Expression Cutting Machine
Is there a replacement strip for under the slide
http://www.cricut.com/shop/#0/1/349/3/Cricut/Cricut%20Expression%20Machine%20Replacement%20User%20Manual
This has a list of all the replacement parts on the left side.
Mar 09, 2011 | Cricut Expression Cutting Machine
My LCD on my cricut expression machine will not work
after doing some research i found a lot of problems with the machines purchased this xmas exp the colored ones the best thing is to contact cricuit and see if they will replace them
Jan 11, 2011 | Cricut Expression Cutting Machine
Crafts & Hobbies Logo
151 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
