SOURCE: Whirlpool Cabrio Washer Error message code F1
HELLO, Error code F1 indicates a control failure and most likely the machine control board will have to be replaced. Depending on when you purchased the machine, the board may be covered under extended component warranty.
I had the same F1 problem and they had to replace the control board and something relating to the balance. The tech told me this is a common problem.
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Maytag Bravos Steam dryer that reads service error code F1
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
http://media.fotki.com/1_p,wkwdffkrdwtbgwsxgtqsskgwtqkq,vi/ksskgsfwrxksrttqdqr/1/1303472/5961857/image12923img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
SOURCE: Hi. I have a electrolux EDC
Actually E50 is an undefined error. For me it was two things, the start capacitor needed to be changed and after very much work of testing every part of my dryer electronically and mechanically it was clear that the motherboard/controller was the main cause. I tried swapping out the relays and the capacitors on the board that looked suspicious but the error prevailed leading me to conclude that some part of the logic circuit was damaged.
The motherboard part is impossible to buy online it seems. The likely reason is that the same board is used in many dryer types and a certified reseller needs to manually program it for your type. However it "only" cost me roughly $150 and it is moderately easy to swap out (top off, front panel off to get to the screw/s that hold the motherboard box, pull the box to the right and then it's free). It really pays to ask more then one dealer about the price for this part because the highest price I got was >$300 and I couldn't return it if I was wrong about it being the problem (I wasn't).
Hope this helps someone. I don't repair stuff for a living but after learning everything I have in fixing this problem I don't regret spending the time on it. However if you are not interested in electronics or fixin stuff yourself, do yourself a big favor and take the dryer to the shop if you get the infamous E50. At least now you know what the problem likely is and can make it sound like you know what you are doing when talking to the repair man ;)
cheersEiki, Iceland
I appreciate your inquiry, Ape!
From what you have described your Electrolux dryer is displaying an error code of "E75". An"E75" error code is not showing as a valid error code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your dryer. You can do that by disconnecting the power from it for ten minutes. Could you please provide me with your model number? You can normally locate the model number on the serial tag which is located on the door frame. Also, once you reset it can you provide feedback if you continue to receive that error code. Good luck. -Matt
Thank you for your inquiry, Leanne!
From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
Hi - Typically error code E08 on Electrolux models indicates that it is recommended for a professional to check the mist value on the motor. Try resetting the unit by unplugging it or flipping the breaker to the household circuit breaker. Wait approximately ten minutes and turn on the dryer. If the error code does not clear and it is ineffective, contact a professional to move forward accurately.
