SOURCE: Can't take pictures-all buttuns don't work
hi, look for my answer in another fx8 topic! there is a soft reset combination. just switch to record mode, press the shooter button, hold it down, and switch the camera on. it is a some kind of reset. it worked me.
SOURCE: sony digital still camera cyber-shot dsc-f717
http://esupport.sony.com/perl/news-item.pl?news_id=161&mdl=DSCF717
SOURCE: My mobile camara says capture failed when i try take a picture.
Please change the resolution of your camera and then try.
SOURCE: Sticks in either automatic forward or reverse
The above image is a close-up of the clutch contact assembly. The illustration shows the correct positioning of the contact wire (a "j" shaped contact) to the camstack pad. To make this adjustment, remove the 6 - T15 TORX screws from the bottom cover and separate the bottom cover. Unplug the projector and remove the lamp module. GENTLY make a very slight bend to the wire to get it closer to the location in the picture. Turn the projector on, cycle it 3 or 4 times and check the position of the pad to the wire. Repeat until you get the position shown above. Good Luck !!
