Question about Maytag Washing Machines
Washer does not progress through cycle
When we turn the dial to begin the wash it never moves forward. We have to set a timer and go out to the washer over and over to turn the dial to the next part of the cycle.
  • 44 Answers
It might be the pressure switch which in part controls the cycles eg when water enters drum air pressure builds up through a tube connected to pressure switch which has electrical contacts.it is round in shape and if is the fault, it has to be replaced. regards
Posted on Jul 29, 2009
Hoover 700LB - fills as per normal and washes but cycle knob does not move, click or progress towards the next cycle therefore washes forever...timer perhaps and if so is it worth fixing?
Hi just read your posting.Does the timer move at all from the original position that you started it from?If it does not move at all then you need a new or reconditioned timer.If it does move but stops at a specific spot,What position does it stop at?Are you in Australia? If so I can give you the contacts on where to purchase a timer.Please reply and I can guide you on how to get the correct timer number for your machine.Looking forward to your reply.
Jul 24, 2010 | Hoover HTC243 Top Load Washer
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Does not progress through cycles. Washer will fill and agitates, but must be moved manually to each succeeding cycle (drain, rinse, spin, etc.) Wherever it is set in the cycle, it remains there.
It sounds like a defective timer. The timer is behind the dial that you use to set the cycles. You will need to remove the screws that hold the top control panel down. Once these screws are removed the panel will flip up. Then you will be able to get to the timer. Verify that there are no loose connectors causing the problem. Also blow out the timer with compressed air to clear out any dust that might be causing a malfunction. Otherwise you may need to replace the timer.
Dec 19, 2009 | Estate TAWB600JQ Top Load Washer
I have a Hoover 550 MB Top Loader washing machine . The cycle won't move from wash to spin . it doesn;t progress out of wash cycle , it stays there forever .
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Oct 19, 2009 | Hoover HTC243 Top Load Washer
The washer will not move forward automatically. I
it may be the timer or the heater has gone faulty in which it will not advance the timer from the stats. is it heating ? if not theres your answer, if so it may be the stat or the timer itself.
Mar 16, 2009 | Washing Machines
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
New Whirlpool washer model WTW5700SW rinse cycle doesn't worker properly. The water never fills the tub & continues to drain. You have to manually move the dial to the end of the rinse cycle to have...
Sounds like what you are describing is the timer on the dial is not activating the next cycle. Timers are usually the problem when the cycles do not complete there cycle
Dec 03, 2017 | Whirlpool Washing Machines
The washer does all the normal processing but the dial progresses but the washer just washes, washes, washes. It is almost 40 years old (Maytag). When rotating the knob to the wash setting, the internal...
hi thanks for the question i would replace the timer that washer you have is a very good washer a lot better than whats out there keep repairing very good washer thanks the appliance doc
Sep 27, 2008 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
