Question about Crafts & Hobbies
I have a Lionel train set 7-12000 the whistle works all the time. It's a yankee major league set with a transformer.
SOURCE: My new Lionel CW-80 trans former stopped working
I have had the same problem with my polar express, which i just bought recently. Having to send it to the USA from the UK would be very expensive so i decided to open it up myself. The tamper proof screws were a bit of a problem getting into it. I ground down an old screw driver into the triangle shape to undo them. I then replaced them with self taping srews the same size.
The Problem I found was simple, there is an internal (250V, 8Amp) fuse soldered onto the red wire on the secondary winding of the transformer. The red wire going from the transformer to the PCB, the fuse has black heatshrink over it.
There is no room inside the housing of the controller to fit a fuse holder. I fitted a box on the side of it with a panel mount fuse holder. drilled a hole through the housing, fitted longer red wires, so they could go through to the terminations on the back of the fuse holder.
At least now I can change it simply if it blows again.
hope this is of help to you.
Posted on Dec 08, 2008
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
SOURCE: New Lionel Polar Express train set-up issue. The
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
Posted on Dec 25, 2010
  • 10 Answers
SOURCE: No longer have manual for
See link below to PDF file with instructions to your transformer. It looks like you are correct with regards to the wiring with what I can see in the manual.
Hope this helps and good luck
www.lionellines.com/files/manuals/KW_Manual.pdf
Posted on Aug 04, 2011
  • 13 Answers
SOURCE: my lionel train won't run at all. What do I do?
bad connections, wires to/from the transformer, or maybe a real dirty track.
try spraying a very small amount of CRC [brand ) 226 it is better than any contact cleaner on the market. do not get it on the rubber traction wheels on the engine. If you do, wash off with alcohol using a cotton swab on the rubber band on the traction wheel.
Posted on Nov 20, 2011
Lionel 2466WX Tender -- HOW do I get it to WORK? (Assuming that it does work)?
Good work, Dan! Fixing trains can be as much fun as running them.
Apr 22, 2014 | Crafts & Hobbies
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
The whistle on either side of my 1966 lionel zw transformer does not work
The contacts on the switch may be dirty but the most likely problem is that both selenium rectifiers are dead. Replacement silicon rectifiers are available if you want to do the repair yourself. Check the internet for suppliers. You can get the ZW repaired at most good Lionel service centers for a reasonable price. Get a list of service centers by searching on-line or at Lionel.com.
Mar 05, 2014 | Crafts & Hobbies
Lionel train problems
Make sure the A or D terminal is connected to the center rail. U terminal to the outer rail. First do this without the sound activation button. Horn should sound this way. Once this works correctly, add the sound button in on the center rail lead (A or D) If the sound activation button activates the horn, reverse the connections to the sound activation button.
This should solve your difficulties
Dec 04, 2013 | Crafts & Hobbies
Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Jan 05, 2013 | Lionel New Haven Freight Train Set
My lionel rw transformer won't run the train unless ithe speed control is turned 3/4 way up or better . Can this be fixed ?
Yes. Find a Lionel repair shop or bring it to a local hobby store that does model train repairs. You can contact Lionel for a list of repair shops.
Dec 25, 2010 | Lionel Cw 80 Transformer
WHISTLE STOPPED WORKING on CW-80
replace the button with a new one just remember which wire goes to which terminal. you will need a soldering iron and electronic solder to do this trick , also make sure you un plug the transformer. by any chance you got any n-scale trains you want to get rid of . If you do send me the info @ robert.e.kelsey.jr@gmail.com I'am a disabled veteran with little funds.
Nov 30, 2008 | Lionel Cw 80 Transformer
Crafts & Hobbies Logo
63 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
