Question about Toro Lawn Mower With Toro Power Tools
Replace 105-1844 traction cable on toro mower #20017
I managed to get the old cable off. But I see no way to thread the new cable though the spring. There is very little space to work in near the transmission. even if I could get the spring off, I'd never get it reconnected ( the "U" at the end is .5 in long). Do I need to remove the transmission to get access to the spring? Must the stabilizer bar be removed to unblock the transmission? I've read on-line that this part wears out quickly, so there ought to be a simple way to replace it?? Any help would be much appreciated. :)
  • totalogy Jul 31, 2009
    Phew! When I picked up the replacement cable it included an attached spring. I only loosened the stabilizer bar to swing it out of the way so that i could remove the old spring. It was slightly difficult to get the new spring attached in the restricted space, but it's done! :)
4 Suggested Answers
SOURCE: the cable traction cable is broken on my toro
I changed the cable on my toro mower but i cant make it go unless i pull back on the handle .i cant find a picture to see what i am doing wrongcan you help. Thanks
Posted on May 06, 2009
e-Guru
  • 3917 Answers
SOURCE: I have to replace the
The black cover on the front of the mower is held on by couple of screws from underneath. You have to remove the cover which will give you access to where the cable connects to. Then use a pair of pliers to squeeze the end of the cable to disconnect it from its mounting hole. Now loosen the cable clamp, pull the cable downward to remove all the slack then push the cable jacket up 1/8" and secure with the cable clamp.
Posted on May 25, 2011
SOURCE: Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
Posted on Mar 12, 2012
How is the traction cable adjusted on Toro Model 20027, Serial # 20005663. I'm replacing the cable and the new one is slightly different from the old one, but the Toro shop tells me it's the proper...
There is a large black plastic nut at the end where the cable attaches to the mower transmission. Turning it clockwise tightens the cable (engaging traction bar is tighter) and counter-clockwise is loosening the drive. If the cable is a little too long, you have to tighten it more.
Sep 27, 2017 | Toro Power Lawn Mower
Toro 20017, bevel gear, pin groove removal
did they get you the parts yet?
Mar 25, 2014 | Toro Garden
My spark plug wire was damaged. I went to Toro dealer and bought a new coil, and new rubber boot for spark plug. It was easy to replace, but after it started up, which it always does on first pull, I...
The contact point that grounds out the spark is not connecting. Take it apart back down to where you have access to the coil and check the mechanism and and the wire to ground out the spark.
Sep 02, 2011 | Toro Garden
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
I have a self-propelled Toro Personal Pace lawnmower, Model 20022. Both rear wheels engage and rotate when I lift the rear wheels off the ground, but when I put the mower back on the ground, the right...
Routine maintenance is required on the drive gears on these Toro mowers and Toro doesn't tell anybody. Put a block under the rear end to lift the wheel off the ground. Remove the wheel. You will see the drive gear. VERY IMPORTANT: take good notes, pictures, etc..when dissasembling. Remove the outer snap ring retainer from the axle shaft. Next should be a thin washer. Remove the washer. Pay very close attention to the gear, as it has to go back on in exactly the same direction. Remove the gear. There is a slot in the axle shaft. Rotate the axle to have this slot pointed up. In the slot is a small key (rectangular piece of metal), remove the key. Under this key is a spring. It, and the key, is stuck in the axle slot, therefore not allowing the gear to drive the wheel. Dig out the key and spring, clean them and the slot. Put a dab of axle grease in the slot and reassemble. In my shop, this is part of a mower tune-up, and is recommended every 50 running hours. That is usually every other year for the average home-owner.
DO NOT TIP your mower over to do this repair. Mowers are just like cars, they like all 4 wheels to stay on the ground. Tipping a mower over can/will cause fluids to go places they aren't supposed to go.
This is a relatively simple repair and can be done with basic mechanical knowledge and basic tools.
Do the other side too, it needs it.
Sep 11, 2010 | Garden
Toro Lawn Mower 20017 serial # 250000001 shaked and smoked while
drain the oil...the gas seeped into the cylinder and into the crankcase...fresh oil, a clean plug, should do the trick...
May 02, 2010 | Garden
Aug 14, 2009 | Toro Lawn Mower With Toro Power Tools
I have a TORO 6.5HP Mower Model #20017 Self Propel Drive-
check cable.check belt and check gearbox.one of these will be bad.if not all
Jul 21, 2009 | Toro Lawn Mower With Toro Power Tools
Mower won't keep running after 10-15 seconds.
check the air filter & also spray some carb.clean in the carb see if that helps
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
2,064 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
