Question about Viper Vehicle Parts & Accessories
Car with viper remote starter starts but shuts off when the door opens?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
That's a theft deterrent feature. Sounds like the programming needs adjusted. It's assuming that the car is still armed or perhaps it is? If the car is unarmed it will not shut the vehicle down when the door is opened.
Posted on Dec 03, 2017
SUL827
  • 93 Answers
SOURCE: My car alarm is blinking
You need to first look under the drivers side dash area near the hood release/fuse panel area and see if there is a valet switch. The switch will look like a little toggle or a push switch. After you locate it, turn the ignition switch to the on position(dont start it) and flick the valet to the opposite position it is in now. If done correctly in most cases the red system light will stay a constant instead of off or blinking indicating you are in valet mode. Next try to start the engine. If this doesnt work you need to remove the alarm system and repair the ignition switch wiring or replace the electrical portion of the ignition switch. The aftermarket alarm cuts into the ignition switch wires and bypasses the start circuit through the alarm module. When disarmed the alarm completes the circuit and allows the car to start. Good luck hope this helps and please rate this.
Posted on Nov 27, 2008
  • 22 Answers
SOURCE: Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Posted on Dec 04, 2008
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
  • 24 Answers
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Posted on Nov 04, 2009
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
Will not unlock doors. Battery is good and flashes all lights on transmitter and LED inside vehicle. Remote start will start up and shut down vehicle fine. Just does not lock or unlock doors. Locks work...
Have you changed the battery recently? My remote has a bad habot of slightly misaligning the cel switches if I don't close it exactly right. For my Chrysler van the sliding door switch is affected that way. All else works, though. I end up opening the remote again and ensuring it snaps shut all the way around with just one compression. If an edge doesn't close it's try again. The good news is it's virtually always the remote at issue and nothing expensive in the vehicle.
Jun 06, 2017 | 7900 RB 7900 2Way Color LCD Remote Start...
I just had a Viper VSS4000 installed in my 2011 Camry. The car has a smart key system, so everytime I open the door when the car is remote started, the engine shuts off and I have to turn on the car with...
Sorry, there is no take over feature available for the 2011 Camry considering that all doors must be closed to perform the remote starter sequence.
Mar 10, 2011 | Remote Start System
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Jan 05, 2011 | Remote Start System
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
Mts mode for preset manual trans auto start function enable,does not allow car to start, instead the park light blinks seven times and give an error tone ... Thank you
There is a sequence necessary to set the Viper every time you exit the vehicle: park the vehicle, put in neutral, place foot on brake, set parking brake,remove foot from brake, remote start vehicle with remote, remove key (vehicle should remain running), exit vehicle and close door, arm the alarm with remote (vehicle should shut down). The system is now set for MTS remote start. Test the system by remote starting the vehicle now (it should remote start at this point). If you open any door after the MTS remote start has been set, you will have to do the programming sequence again.This is a safety feature because something may have changed, i.e. parking brake released when the door was opened. You have to do this sequence each time you park the vehicle if you intend to use the remote start feature.
If this does not work, there may be an issue with the installation, i.e., the door trigger connection. Using dome supervision as a door trigger won't work because during the arming portion of the above mention programming sequence(when the vehicle shuts down), the interior lights will illuminate and the Viper will read it as a door opening. So, actual door trigger wires must be used.
Oct 23, 2010 | 5900 SST 2-Way Security System / Remote...
Key will not shut vehicle off after staring with viper starter
The brake is what shuts it off. To keep the car on You first put key in to IGN position then hit the brake. If you hit brake first then the remote start shuts off
Nov 24, 2009 | Remote Start System
Dec 12, 2007 | Viper (VGC421) Remote Control
Vehicle Parts & Accessories Logo
119 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
