Question about Viper Vehicle Parts & Accessories
By pasing securety sestum in my chevy siverado 2001 hd 2500 I changed stering collums and ignition wiers .now truck is not staying on .how can I get it to stay running
Arter removing viper security alarm and all wires that were installed to the ignition wires the truck dos not stay running now with new ignition swich and wires .
  • 29 Answers
SOURCE: Blower won't shut off
You will need a Blower motor resistor and maybe a blower motor resistor connector end. If you look under the dash on the passenger side(may need to remove smooth black cover, vents will be sticking out) you will see a connector going straight up into the blower motor resistor(7 wires/slightly in front of blower motor). Pull out the connector and check for melted terminals/wires. If no melted terminals just replace blower motor resistor with part # 89019088 per GM to revert to part before 04 in order to stop blower motor resistor relay from hanging. Let me know if i can help more.
Posted on Jan 02, 2009
  • 3600 Answers
SOURCE: how to remove lower ball joint 2001 chevy silverado 2500 hd 4x4
The reason is they are pressed in and you have to press them out with a tool and some have a C clip that has to be removed you can go to schucks or autozone to rent the tool to press out and it has to be pressed back in.
Posted on Jul 25, 2009
  • 7353 Answers
SOURCE: how to disable passlock system on 2000 Chevrolet
There isnt any way to disable it that I know of, if you could, anybody could steal the car. It just needs to be fixed by a qualified repair shop or the dealer.
Posted on Nov 23, 2009
  • 518 Answers
SOURCE: fan stays running with key off. Have changed
which fan? if you are talking about the engine fan, it will run on until the temperature drops, but if you are talking about the heater fan, thats not right
Posted on Feb 01, 2010
SOURCE: 2005 chevy colorado .Security alarm flashes when
2006 colorado..security system keeps me from starting the truck , but not every time. i had a new key made but the security symbol pops up now and then too. can the system be turned off//
Posted on Sep 22, 2010
How to disconnect chime on 2001 Chevy 2500 hd
That annoying Seat Belt, Key in ignition Chime??
set it up so it chimes, then look under steering wheel/Dash you should be able to locate the chime unit and just unplug it.
Apr 16, 2015 | Chevrolet 2500 Cars & Trucks
2001 chevy silverado shuts down with no hisitation not like a fuel problem when it shuts down it will start back up in about 30seconds or so
GOT SAME PROBLEM CHEVY DAURMAX DEISEL HD 2500 CHANGE FUEL FILTER AND OIL &OIL FILTER . WHEN YOU COME TO A STOP SIGN OR RED LIGHT IT HAPPENS .I PUT IT IN NEUTRAL AND PUMP ON GAS SO RPM'S STAY AT 1800 RPM'S
Mar 02, 2013 | 2001 Chevrolet Silverado 2500
My 2001 Chevy 2500 HD 6.6 L turbo diesel won't
fuel injection pump is failin or has issues--getta haynes manual for pro car maintenance
May 30, 2012 | 2001 Chevrolet Silverado 2500HD
I have a 2003 chevy siverado 2500 hd and knock sensor code is on but truck runs smooth what should i check before taking it to dealership
Hi, the knock sensor helps the computer optimize ignition timing and yet avoid detonation. When the sensor fails, the computer defaults to a timing that is less fuel efficient. Replacing a knock sensor is usually easy, provided there is access under the engine. Depending on which engine you have, it's usually centered on the block just below the cylinder head. There is one sensor on each side, and the trouble code should have indicated bank 1 (driver's side) or bank 2 (passenger's side).
Please let me know if you have more questions, and thanks for using FixYa.
Typical knock sensor:
Mar 28, 2011 | Chevrolet 2500 Cars & Trucks
91 chevy Siverado 2500 AC Blower problems
My guess would be the same as yours. Good job.
Jun 23, 2010 | 1991 Chevrolet Silverado 2500
The steering collum is loose.
you need to get a new steering column in there asap. i had one do that to me and it ended up breaking on me
Feb 21, 2009 | 1991 GMC Sonoma
2002Chevy Silverado 2500 HD Pick up - Security light staying lit...
that has something to do with the reprograming of your ingition key if you are having not starting problems i will recomend you to leave it alon but if you wnat to be in the safe side then call one of the mobile locksmiths guy or take it to them to see if the key has to be reprogamed, and try using only one single key for the ignition,
some time systems take a little be to reconigse a copi made key
May 20, 2008 | 2002 Chevrolet Silverado 2500HD
Vehicle Parts & Accessories Logo
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
