Question about GE DBVH512EFWW Dryer
Dyer is not turning on acts like it is not getting power
  • GE Master
  • 8,220 Answers
The fuse is located on the rear pan here the heater is. Remove the screws holding down the top and then you can raise the top up and get the front off. the fuse part number WE4X800 looks like this:
dyer is not turning on acts like it is not getting - 7b78f21.jpgHere are some REPAIR PICTURES
Posted on Jul 29, 2009
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
Maytag performa electric dyer makes dragging noise drum turns but acts like something catches and makes a dragging or scraping sound
assuming nothing is stuck around drum pull off the front and check the fan. If it is noisy for a few seconds after you stop the dryer then the fan may be stripped on motor shaft. while off you can check the front glides and the rear rollers
Nov 17, 2010 | Maytag Neptune MDE4000 Electric Dryer
HE3 Dryer not heating
check the thermal fuse and also check to make sure you have 220v at the outlet.
Jul 23, 2010 | Kenmore Elite HE4 Electric Dryer
Dyer is getting power but will not turn on
dyer will not start with start button,but will run with cycle button in cycle when you turn it to the cycle want
Nov 14, 2009 | Kenmore 62602 Electric Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Dyer not turning at all
Is the dryer getting power? Check to make sure that the circuit breaker hasn't tripped of been turned off. If the breaker has tripped, you may have a short circuit in the dryer unit and you should have the unit check by a qualified technician.
Jul 22, 2009 | Kenmore Dryers
Attaching Power Cable
The two outside wires of the flat power cable are the power wires. The middle wire is neutral or ground.
Hook one of the red outside wires to the red, the other to the black, and the center one to white.
Feb 13, 2009 | GE Dryers
Dyer on combo won't start
This could either be a bad start switch or door switch
May 29, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Dec 24, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
126 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
