Our washing machine only fills with water and does not proceed through the cycle to agitation. We can manually move the dial to spin, but its stuck in the initial position wasting water. I would say it was a machine problem, but we just replaced the machine! So that two machines in a row with the same problem. Is there something that could be wrong with our water or electrical hook ups that might be causing this problem? We have the hot and cold sent to the right hoses. Help!
  • Eric Lybeck Jul 29, 2009
    It'll do each of the cycles if we manually move the dial. The actual cycle won't proceed. I would say it could be a problem with the machine, but we literally just installed this machine yesterday and the same exact problem was why we got rid of the other one. Is there something that could be wrong with the electrical outlet, you mentioned there could be something wrong coming from power outages. This looks like the only machine on the breaker circuit, should I reset the breaker? It seems like too much of a coincidence for the same problem to be coming up on both machines in a row. Thanks for your help so far!
    President:
  • 1,776 Answers
Does the machine have the capability to agitate? By this, I mean is the timer just not advancing or will the machine just not agitate? If it is capable of agitating, but the cycle just won't advance, it is usually caused by a faulty cycle timer. If it can't proceed the cycle because it can't agitate, then the problem could be a defective lid switch or some other defective component (motor coupling, transmission, etc.) Does it spin and pump out the water? I would check the lid switch first. It is inside the main housing near the door frame. The switch can be checked for continuity to see if it is faulty using an ohm meter or multimeter. If there is no continuity, the switch is defective and must be replaced.
As for your other question, and I don't know what the problem was with your old washers, but I really don't see how your water hook ups could cause a problem. As for your electrical hook up, you can meter the dryer cord for continuity and you can check that the outlet you are plugging into is providing the right voltage, but I think that it is probably just bad coincidence that you are experiencing similar problems to the ones you had in the past, although I have seen people who live in an area that has alot of power failures have problems, but it usually affects more than just one appliance or piece of electrical equipment.
Hope this helps and feel free to let me know any additional info that you think might be useful and I will do my best to help you figure it out. Best wishes.
Posted on Jul 29, 2009
  • Bruce Canfield
    Bruce Canfield Jul 29, 2009
    Since you can manually make the machine operate the various cycles, it is a defective timer and will have to be replaced. If this was the same problem that you experienced with your old washer and you suspect that something is causing it, all you can do is investigate. First, make sure that there is no indication that water is getting into the electronics somehow and look for an unusual level of corrosion on all wiring connections. Make sure that there are no chemicals being stored close to the machine that could have corrosive effects on electrical connections. You can use a multimeter to check the main power cord and the block on the machine. Also, check that the appropriate voltage is being supplied at the house's electrical outlet. Make sure that the house breaker for the circuit that the washer is on is operating properly. It is very rare that a breaker is bad and causes these type problems, however. These are some of the things that you might look at. I am sorry to hear about the problem that you are having and have had, and I hope that you find a resolution. Good luck and best wishes.
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Indesit Washing Machine not proceedding with the cycle programme after filling with water.
Cant understand how the machine will revolve on the 'spin cycle' & yet you can hear the motor on the 'wash cycle' but yet it doesnt revolve!!
Nomally if the water fills, & the tub revolves without the programmer advancing, its because the heater is not working. ie faulty thermostat, heat element, or maybe a wire burned off in the 'heater circuit'. Check if you have 240 volts at both ends of the heat element, with a meter or 240 volt bulb
                         !! BE CAREFUL OF 240VOLTS!!
Oct 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
