Question about Energizer CHFC: Family Battery Charger
Hi I was charging a 9v energizer rechargeable battery and the top bot busted open?
2 Suggested Answers
  • 544 Answers
SOURCE: My new Energizer CH15MNCP4 battery charger can
It could be possible that 1 of your 2300 mAh AA battery is defective.
Try to charge only 2 2300 mAh batteries at a time to see if it can charge.
Posted on Jan 20, 2011
Energizer NiMH CHFC2
These chargers run off of timers so as to not over charge. If you want to charge larger capacity batteries you will need a better charger such as MaHa.
Jun 02, 2014 | Energizer Rechargable Battery with Charger
Energizer CH2PC-UK battery charger' how long do i charge AA and AAA batteries
Charge time depends on the mAh capacity of the batteries (should be listed on the package, or the side of the battery) most AAAs are under 900mAh so 2 hrs should be sufficient, but AAs vary greatly in capacity so heres a link to check after you look up your mAh rating
http://energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Jan 14, 2011 | Energizer Rechargable Battery with Charger
Can I use only kodak batteries in my easyshare or is the energizer AA batteries ok? Will I ruin my camera if I install energizer?
Hi. You can use any make of 'normal' non-rechargeable alkaline AA batteries, or rechargeable NiMH AA batteries, but those will also need a battery charger.
Rechargeable batteries and a charger are more expensive to start with but are much more economical in the long run and especially if you use your camera fairly often.
The latest 'Hybrio' types hold their charge better when stored, but again they are a little more expensive but they can all be used in most other gadgets. The ordinary NiMh batteries do not hold the voltage quite as well as Hybrio, or even the older type of NiMh batteries but this does not often matter.
You will find that the capacity of rechargeable batteries varies from about 850 to 2100 'mah' (milli amp hours), so some will last longer than others but otherwise it does not matter which type you use. The latest 'Hybrio' types hold their charge better when stored, but again they are a little more expensive.
You will not damage your camera if you install energizer, so have fun with it!
Dec 27, 2010 | Kodak EasyShare C160 Digital Camera
I have a wii system and use the energizer nimh battery pack with the wii charger. When I put them in the charger it flashes red. Reminds me of my camera battery charger, but I have learned how to reset...
I have this issue with one of the batteries in my set. (Purchased last summer). It is a PL-7522
It seams to be the battery, as I have tried combination of charging ports and controllers. The other battery seams fine.
Dec 24, 2010 | Energizer NiMH Compact AA/AAA Battery...
My batteries (enregizer nimh rechargable) will not charge and the red light shuts off quickly.
It sounds like your batteries are defective. If possible get some more same or similar batteries to repeat the test on the charger.
Dec 19, 2010 | Energizer Rechargable Battery with Charger
Kodak Easy Share Printer dock plus. Original
you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Can't get any power running on my 5500 hr life cycle
Change the battery. It is a 9v battery behind the small door on the back of the display panel.
Mar 15, 2009 | Life Fitness 9500RHRT Recumbent Bike
Energizer CHDC charger suddenly not indicating if charging or not
It sounds like the PC Board which provides the circuitry for the Charger's indicating light is malfuntioning. If you have a DC volt-meter, you can check the Charger's output voltage, and then the Battery voltage to determine if your charger is functioning.
Hint: If the Charger has an output voltage, but the Battery's voltage is less than its rated voltage... it's time for a new battery.
Mar 11, 2009 | Energizer Rechargable Battery with Charger
Energizer CHFC: Family Battery Charger Logo
Top Energizer Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Energizer Hardware and Accessory Expert? Answer questions, earn points and help others
