Question about HP Business Inkjet 2200 Printer
HP Inkjet 2200 is no longer printing yellow, after several cleaning cycles. There is plenty of ink in the cartridge (according to the printer), and all of the print heads tested OK. The printer has sat unused for several months. I used a damp cloth to clean the print heads and the yellow prints absolutly nothing. Thanks in advance!!
  • 99 Answers
Need to put a new yellow printhead.
Posted on Aug 04, 2009
Tip
HP and Canon Ink Series Printers – Hot Water Printhead Flush
When an inkjet printer (most newer HP and Canon inkjet printer models since 2006) exhibit poor print quality, missing color(s) or image streaking, flushing the printhead with warm water for several minutes will usually resolve the issue. It is first suggested to ensure ink cartridges have plenty of ink and to perform a 'Clean Printhead' action at the printer before attempting the water flushing procedure. This procedures is applicable to individual ink tank printer models that feature a removable Printhead assembly only. HP 564 HP 920 Ink Series Printers Hot Water Printhead Flush
on Apr 01, 2015 | Office Equipment & Supplies
HP5550 printer is printing everything in green. We have true HP cartridges
So, your "blue" and "yellow" ink-cartridges are OK, and are mixing to produce "green".
But, either your "red" ink-cartridge is empty, or the ink-jets that shoot that colour onto the paper are BLOCKED.
Run a print-head-cleaning-cycle, using the HP Support Tools that were installed from the HP CD-ROM, and then, if necessary, replace/refill the "red" cartridge.
Aug 30, 2010 | HP DeskJet 5550 InkJet Printer
My HP Inkjet 6122 has suddenly started printing color photos with stripes. I don't use it very often, only when I need color photos. I have replaced both the #45 black and #78 color cartridges with genuine...
Use the HP Printer Assistant software tools to run a "head-cleaning" cycle -- the problem is not with the ink (there is plenty of it) but with the print-heads (that **** the ink, and then spray it onto the paper). Some of the jets are clogged, and so you get "white-stripes".
Aug 19, 2010 | HP DeskJet 6122 InkJet Printer
I can't print yellow on HP882C. Brand new HP ink
is it a GENUINE cartridge.....!!!!!!!!!!!!!!!!!
Apr 08, 2010 | HP DeskJet 882c InkJet Printer
Empty yellow cartridge, but cannot print in black?
Most printers use a little of all inks in their functioning, just to keep all the inks flowing, so while it is not printing yellow, it uses it in the startup mode to verify function and cleaning mode to clean the nozzles. Manufacturers usually do not put in a bypass for this, because they make money mostly on selling you ink cartridges.
Jan 20, 2010 | Brother DCP 165C Compact Color Inkjet...
HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Apr 10, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP PSC 2410xi color printing issues
Try using warn distilled water and Q-tips to gently clean the area where the ink cartridge and the carriage mate up. You may have dried old ink in there which is clogging the print nozzles. Allow to air dry, reinstall cartidges, start machine and let it go through its cleaning cycle. Also check www.hp.com. Hope this helps.
Jan 30, 2009 | HP PSC 2410 All-In-One InkJet Printer
1220c Ink blockage
Sometimes the nozzles get clogged. If several normal cleaning cycles do not clear all the nozzles, next try removing the cartridge and setting it, nozzle-side down, on a steaming-hot damp paper towel for a few minutes, then running a cleaning cycle. If this doesn't solve the problem, as a last-ditch effort the head can be soaked in a shallow dish of alcohol for a few minutes. This cleared up a clog for me that no other method would solve, but I have heard that if soaked too long in alcohol, the head may be damaged.
Nov 15, 2007 | HP DeskJet 1220c InkJet Printer
HP Business Inkjet 2200 Printer Logo
197 people viewed this question
Seeker5211
Seeker5211
