Question about Dometic Rooftop RV Air Conditioner
Emerson quiet cool cycles every 6 mins
If it's normal to cycle that way how is it expected to cool in hot weather?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
YOU ARE HAVEING A SHORT CLCLE PROBLEM COMPRESSOR SHOULD NOT SHUT OFF UNLESS THEMOSTAT SAY OK AT TEMP OR UNIT FREEZES UP AND FREEZE STAT SHUT COMPESSOR OFF USUALLY REALLY SHORT CYCLING LIKE YOU ARE EXPERANCING IS CAUSE BY COMPRESSOR OVERHEATING OR FAULTY THEMO SHUT OFF ON CMPRESSOR REPAIR SHOULD BE DONE BY LICENCED TECH
Posted on Aug 01, 2009
DOMETIC DUOTHERM KICKS THE BREAKER MAY RUN FOR A DAY OR MAY RUN FOR 8 HOURS BEFORE IT DOES IT IN MILD OR HOT WEATHER. ALREADY REPLACED BREAKER AND MADE SURE WIRES ARE TIGHTNED. HELP PLEASE.
If all appears OK, no noise, good cooling suggest check thermostat. If the thermostat is allowing the compressor to short cycle, restart under load the breaker would be expected to blow do to overloading the compressor.
There is usually a 5 minute time delay in the thermostat that prevents this.
Jun 20, 2017 | Dometic Heating & Cooling
I start my bike and after 4 5 second engine hed is very hot
Some description of 2-stroke or 4-stroke, number of cylinders, type of cooling would have been useful.
In mild or hot weather the head of an air cooled bike could conceivably be hand-hot in 45 seconds but mostly it would take considerably longer, especially if the engine is a 4-stroke. Of course just because an engine heats up quickly it doesn't mean it will overheat in use and air-cooled engines should not be operated for long while the bike is stationary, except in cold weather, but be put into normal use as soon as possible after starting.
If the engine is overheating there are various things that could influence or cause it. Ignition timing, valve timing, fuel air mixture, lubrication, detonation, restricted exhaust...
Aug 22, 2015 | Motorcycles
Why wen its hot outside my 2000 cadillac devill run hot
When is the last time the cooling system was flushed? You car may run fine in cooler weather but not have enough reserve in Summer especially with AC running. Make sure you don't have leaks, deteriorated hoses or a slipping fan belt. It could even be the thermostat but that is less likely if the temp is normal in cooler weather. Make sure the fans (if electric) or working correctly also.
Jun 17, 2014 | Vehicle Parts & Accessories
Overheating gage when stop & go -2004 chevy tahoe
natural for engine temp to rise in Traffic - Until Themostat opens ) cooling fan sensor kicks on fan . But Antifreeze is not just a Cold weather item . Coolant is Absolutely Necessary for Hot Days . You must be full to recovery bottle setting of cold when checked prior to start up . Coolant for your make / model is Reddish - Pink colour and should have a reading of -25 thats negative 25 degrees the Lower the Better even - 50 .. Why ?? - 50 is 50 %% antifreeze / Coolant Concentrate MIX Gives Hot weather cooling Ability or very cold weather starting / winter HEAT .
Mar 14, 2014 | 2004 Chevrolet Tahoe
Auto Camry 97 cooling fan is not switching on automatically, the temp gauge shows normal temp. Also both AC and cooling fan works when AC is switched on?
If the temp gauge shows normal, you would not expect the fan to be on much. It is controlled by the coolant temp sensor. If the fan will not come on when the car gets really hot, it is possible this sensor has failed.
It is normal for both AC and cooling fans to be on when you turn on AC to cool setting.
Oct 27, 2013 | 1994 Toyota Camry
97 civic wont crank or start in hot weather
Could be the battery or the starter. I would expect you to know if it was the battery so I'll comment on the starter. Not often, but sometimes the clearance between the starter armature and the magnet is so close that a little wear on the bearings will cause the armature to rub against the magnetic coil around it. This normally is first noticed when the car is hot. The armature has expanded from the heat and is touching the magnetic coil. This causes a very high amperage draw on the battery often to the point where the engine will not turn over.. When the car cools down, it works.. Bottom line - you may need a started.
Aug 06, 2012 | Honda Civic Cars & Trucks
I have a 1984 alfa spider, after driving in hot weather the fuel tank had excessive pressure when i opened cap fuel was released like a over heated radiator cap. Is this common?
was your car running fine? if it was than yes if the ambient temp was over 100 then that is perfectly normal. the gasses in the tank would just expand and cause that kind of symptoms. very cool car btw i love those tiny little things.
Jul 09, 2012 | 1984 Alfa Romeo Spider
Unit cools great but when extremly hot weather occurs it eventually freezes up.
dirty filters in the indoor unit.As the ambient temperature rises the unit will work harder and longer,its fine when its just a normal day because the evaporator coil wont have time to ice up as the compressor will cycle off before the coil freezes totally,but during extreme ambient temperatures the coil will ice up as the compressor will continue running to reach set-point causing the coil to ice up
Jan 02, 2011 | Dometic Rooftop RV Air Conditioner
No water
That water is condensate that is removed from the air. If the humidity is low, you will notice much less water coming from the condensate drain line. I would expect to see some water though.
If the unit doesn't seem to cool as well as it did, then chances are it has a leak and has lost its refrigerant charge.
Sep 18, 2008 | Kenmore 75050 Wall/Window Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
226 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
