Question about U-Line Icemaker
Excess frost I have an older model 45 in my 1990 boat that I have to defrost every week. Any idea what the problem might be? I was told the door gasket might be it but no one seems to know the part number or where to get it.
  • 286 Answers
Your model is a manual defrost, so the warmer the ambient and the more you open the door you will need to defrost it more often. All you can do is make sure the door is sealing and if yes then thats what it is.
Posted on Jul 30, 2009
Unit does not defrost automatically
Faith I would not call that a professional what is the model number of the refrigerator
Apr 30, 2016 | Frigidaire Refrigerators
My refrigerator/ freezer doesn't seem to be too cool. Cleaned bottom coils and left unplugged for 24 hrs. Turned back on and it worked fine for a week. Now it is not cooling again. Any ideas why?
Hello Chris Conrad,
Worked fine for a week... is actually a pretty good sign...
MOST likely means the cooling is OK...
FROST-FREE (defrost)... should become your focus
TYPICALLY... (assuming you have that type of UNIT).
after the week... is it clogged with frost / ice (cool in the freezer area but not the refrigerator... (a week is a little less than average to become non-functional in the refrigerator (cheap little refrigerator thermometers come in really handy here... (but still cool in the freezer area where all the REAL cooling is done))).
Can you see frost/ice blocking any air slots in the FREEZER AREA??
Is water being put in the (I assume) "defrost pan" daily...?
Easy to check... put a strip of typing paper folded over the edge of the (water tray) defrost pan...
Still clean, straight & dry tomorrow = defrost circuit failure
(again.... assuming it is a "frost-free").
Yes (clean & straight) means I am wrong: paper
will look rumpled & ugly (possibly wet).
Then...
You have a HUGE AIR INTRUSION problem you need to fix first... (door alignments, gaskets, etc.) then get sophisticated about makes, model numbers... & how soon it takes to get ICE-BOUND.
You can comment me back... or get out the original
refrigerator documents... (typically) looking for:
- Defrost timer or control board
- Defrost thermostat
- Defrost HEATING ELEMENT
OR
Search on line to parts/spares + appliance+ (your model number).
Good luck...
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
Apr 27, 2016 | Refrigerators
Why does my freezer build up with ice in the bottom
is it a frost free model? if it is the defrost timer may be out or the defrost element may be bad. but if this is not a frost free model the door seals may be bad and need replaced
Aug 24, 2014 | Amana ABB1922FEB (185 cu ft) Bottom...
Model SR-L39. "no frost" dec
The defrosted water that drains to the drain tank has leaked when the fridge is defrosting,it can be due to some puncture in the drain hose from the freezer ,specially when the temperature is high this can be more . You can set the thermostat a little lower to reduce the frosting , also keep a flat tray under the drain tank so that the excess water can be collected and disposed.
If you can check and see if the drain pipe is damaged.
Jul 02, 2011 | Samsung Refrigerators
Freezer with excess frost despite temperature control at proper setting
This is a defrost issue, consisting of three components: Defrost Timer, Defrost Thermostat, and Defrost Heater. In older whirpool refrigerators it is almost always the Defrost Timer. You can easily replace this your self. Just send your model number and I can direct you through your repair. You can order the part you need at, Reliable Parts
Thanks, Repairman45
Dec 19, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Drain pan over flows weekly,i'm thinking defrost cycle is running to much.
Excess frost is building in the evaporation compartment. Air from outside causes this. Look for worn door gaskets or ill closing doors. To make your doors close tighter elevate the front of the machine slightly.
Sep 05, 2010 | Whirlpool Refrigerators
Excess frost and condensation
Could be that it is not getting a good seal when the door is shut. Check for obstructions causing that and check the door seal to see if it needs to be replaced.
Mar 13, 2017 | Sanyo SR-9510W Refrigerator
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
Aug 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
My Norcold DE0051 I have to keep defrosting every 2 weeks
Occasional defrosting is needed on these units. 2 weeks isn't that bad considering the environment that it is in (your boat). Every time that you open the door, moist air enters the fridge, and the moisture eventually collects on the freezer plate, and freezes. Putting foods into the freezer that are uncovered also contribute to this a great deal, as do putting in warm / hot foods before giving chance to cool down.
These freezers do not have automatic defrosters. The target environment typically has limited power available. Automatic defrosters would easily double the power requirements.
You can also check the door seals on your fridge as well. If they are not sealing properly, they can also let in humid air which then causes moisture to collect on freezer plate.
Aug 10, 2009 | Thetford Norcold DE0051 Refrigerator
EXCESS FROST
You have a failure of the defrost system which is comprised of:
1. Defrost Timer
2. Terminating thermostat
3. Heater element
If you have no experience in servicing a refrigerator, I would recommend calling a technician, as it is a rather lengthy training session to write about. Or, you can ask one of our experts who can guide you through.
Tip: Manually defrosting the freezer thoroughly will allow the unit to function for several days until a tech. can get there.
May 27, 2008 | Refrigerators
U-Line Icemaker Logo
61 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
