Question about Samsung 7.3 Cu. Ft. Electric Dryer
It's not a threading issue (w/new Maytag belt)
The belt can only really go on one way that I can tell: looking from the back side- belt feeds to the right side of the tensioner and then down and feeds on the left side around the pulley. With the flat side to the tensioner and the ribbed side then threaded around the pulley it's way too slack. I cannot take the belt back, as I bought it on-line. I was just going by what someone here suggested: as far as I can tell it's the proper part numbers. And, as stated, I'd replaced the belt before, in which case it's not totally foreign: I was soliciting for known installation mistakes, but mostly just to warn people that this belt may not be a replacement (as stated).
If someone has a measurement of a proper fitting belt that would be appreciated. If the belt that I have doesn't work/fit then I'm just going to sh#tcan the dryer (already have a replacement, just looking to get this one working [with a reasonable belt] and sell it).
  • 496 Answers
Sorry the belt is giving you grief. It sounds like you're routing is right. I can only suggest taking your make and model info to an appliance repair and getting a correct belt, especially since you have the dryer apart. Someone always is in need of a dryer. Good luck!
Posted on Sep 01, 2009
The bobbin thread when sewing has little loops
You do not have the tension on your machine set correctly. That is leaving the bobbin thread too loose, hence the loops you are seeing. What kind of machine do you have? I can tell you where the tension is located. Also, tell me what kind of fabric you are trying to sew. FIRST JUST SET IT BACK TO THE FACTORY DEFAULT. When you are moving the machine it is easy to accidentally hit the tension and change it. Here is a picture of what a tension knob looks like. Good luck.
Apr 24, 2016 | Sewing Machines
My White 5500 sews perfectly on the top, but the bottom thread is tangled and messy. I have tried to adjust the tension according to the manual but nothing seems to work. Help!
This is a really common problem especially on side bobbin machines, and the manual will tell you it's a tension problem but it's often a more general thread feeding problem. First make sure you have a good quality thread that isn't old or sticking as it comes off the spool. And more important it can't be too heavy, especially in certain fabrics and with a fine needle. A too heavy thread will cause all the problems you describe.
If your machine uses a bobbin holder and it has a tensioner in it make sure it's clean and well adjusted and has no gummy residue on it. And finally look at the bobbins themselves, I understand older machines work better with metal bobbins vs plastic.
These are very generic solutions but I had similar befuddling problems with a newer Brother side bobbin machine and was tearing my hair out over the thread bunching and Brother support kept insisting it was a tension problem or improper thread routing.
Turned out I was using too heavy a thread.
Since then I picked up an older (1990?) Singer Meritt 4530 from Goodwill for $20, but it's a more expensive top bobbin machine and NEVER bunches or malfunctions. I'm sold on the top bobbin design now, the mechanism inside is more complex but the thread feed from the bobbin is more direct and simple leading to less sewing issues. So you pay more for less headaches.
Jun 01, 2011 | White Sewing Sewing Machines
Thread from spool and bobbin do not connect to make a stitch
(1) Check the needle or replace with a new one. A needle has a groove in one side of it and that is the side that the thread enters the needle. Some thread from the side and some from the front.
(2) Before sewing, manually turn the wheel to make the needle goes down while holding the needle thread with your left hand. When the bottom thread pulls up, pull both threads toward the back of the machine before sewing.
(3) Make sure your pressure foot has been lowered. Sounds silly, but if you lift is high it might just look like it is engaged.
(4) Try it on two ply fabric first and try both a straight stitch and a zig zag and see if you have problems with either.
(5) Make sure your thread is really machine thread and not hand sewing thread.
(6) Make sure the bobbin thread is feeding off the bobbin spool in the right direction.
(7) Anything other than these is probably a tension problem or a bobbin timing problem.
Mar 21, 2011 | Sewing Machines
Top thread will not pick up the bobbin thread. Machine is threaded correctly and am using a new needle. Bobbin case is clean and oiled.
(2) Before sewing, manually turn the wheel to make the needle go down while holding the needle thread with your left hand. When the bottom thread pulls up, pull both threads toward the back of the machine before sewing.
(4) Try it on two ply fabric first and try both a straight stitch and a zig zag and see if you have problems with both.
(7) Anything other than these is probably a tension problem or a timing problem.
Feb 24, 2011 | White Sewing 1730 Mechanical Sewing...
The needle is not catching the bobbin
Feb 24, 2011 | White Sewing Sew Cute SC20 Mechanical...
I cant get my bottom thread to come up?
Feb 24, 2011 | Brother VX1435 Mechanical Sewing Machine
What is the problem when the top thread wont pick up the bobbin thread
Feb 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a Maytag side by side, MSD2434GEW, about 8 years old, the fridge side appears to be working fine, the freezer side is about the same temp as the fridge and not cold enough to freeze anything. It...
the clicking sound is the compressor trying to start . i belive that you need to reolace the relay start on the compressor . the part that maytag has on ther websight is 12002794 about 34.00 .. mm hope this helps feed back pls ..
Dec 03, 2010 | Maytag MSD2434GE Side by Side Refrigerator
Singer Simple.....not really!
You really should go on the Singer website and look up support and frequently asked questions. If, you cannot find your manual they have it there to download for free. I really think that you are not threading the machine right, check it with the presser foot up and the thread should feed freely, then lower the presser foot and it should not feed at all or very little. Most of the bunching of thread underneath is the fault of the top thread not the bobbin. Make sure you turn the handwheel towards you never away from you. Also, check your needle, inserted flat side away from you and, if it were me, I would use a new needle before I sewed again, This machine comes with a dvd, try watching it.
Jul 22, 2008 | Singer 3116 Simple
HOW DO I ?
You probably need to thread the new belt over the drum by removing the circular rubber front seal temporarily. After putting the seal back on, ease the belt into the correct position and thread over the pulley on the motor. You will probably find it easier to put it over the pulley wheel of the motor first, with the belt partially off the drum. Then rotate the drum manually whilst easing the belt over it.
Mar 24, 2008 | Dryers
Samsung 7.3 Cu. Ft. Electric Dryer Logo
66 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
