Question about Garden
Strung will not go back in - Garden
  • 279 Answers
Either the spring is broken or the starting spool has been stripped. When you take it apart see which. Parts are available online. I use http://www.psep.biz/store/small_engine_parts.htm The spring can be a real problem if wound wrong. Look at the spring as you remove it and draw a diagram, you will like it when you replace it. If it is the spool, don't even touch the spring!!! Good luck..
Posted on Aug 02, 2009
Fish from alaska, it was frozen by the time we got it home. I was going to process it in smaller containers, but cant cut thru it. If i thaw it out some so i can cut it will it be okay to refreeze?
do not thaw and refreeze a definite no no ,use a band saw to cut it fish finger manufacturers use this system to create their products
Aug 03, 2015 | Refrigerators
Need to replace heating element,where to open dryer
Hi Deborah. I d not have this model of dryer, but I did a similar job on my front-loader. First you should make sure that the heating element is the problem; in my case, there was a fuse and a thermal coupling that might also have caused this behavior. If you search around, you should be able to find a troubleshooting guide for your dryer that details how to test. You will need a screwdriver and a multimeter to follow the procedures. The manual should also describe how to do the replacement, but the basic steps should be similar for all dryers like this:
1. UNPLUG IT!!
2. make sure it is unplugged
3. remove the top. Usually held on with screws in the back and tabs in the front
4. remove the front. May have to remove the door first. if you have front-mounted controls, you will need to unplug the wiring harness(es).
5. remove the drum. I didn't think it was heavy, but that is a subjective thing.
6. the heating element will be mounted on a panel on the back wll of the dryer, probably on a piece of material covered with a reflective coating.
7. Unplug the element from the cabinet wiring, and remove the backing surface with the element. you can test the element for continuity with the multimeter. In my case, the element was visibly broken.
8.The element will probably be strung on a series of wire holders; unstring it.
9. String the new element on in the same way that the old one was strung.
10. put everything back together, and if the element was the problem, you should b good to go.
Aug 30, 2013 | Electrolux EIED55HIW 27 In. White Electric...
Are there different head sizes for a tennis racket?
there are 3 different head sizes of rackets. here is an explanation of the different sizes from http://www.dummies.com/how-to/content/choosing-a-tennis-racquet.html
Over-sized:
Beginners really like the over-sized and even jumbo frames, which offer between 100 and a whopping 140 square inches of strung surface. Such frames give you a larger sweet spot simply because the hitting surface is bigger, and they allow you to hit the ball farther from the heart of the sweet spot and still make a good shot.
Mid-sized: These racquet heads range from 85 to 100 square inches. Most pro players use frames on the low side of mid-sized - between 85 and 95 square inches. Most recreational players gravitate to the high side of mid-sized - between 95 and 100 square inches. Mid-size racquets offer a great compromise between a larger strung surface and sweet spot and a maneuverable frame that lets you generate good racquet speed when you swing.
Standard-sized heads: Ranging from 80 to 85 square inches, standard-size heads are now obsolete. They give you a smaller strung surface and sweet spot, making it more difficult to produce crisp, clean shots.
Feb 20, 2013 | Sport & Outdoor - Others
Kenmore dryer model 417 won't dry my clothes. It tumbles just fine but it won't get hot.
if it is electric you need a new heating element they can cost around 80 dollars for the string it yourself kind and the pre strung kit cost double that price mabye more . if you are handy i can tel you how to replace the part in detail. I have also written a few time how to replace this part if you look through my solutionshope this helps feel free to write back for more help i would love to assist you
Jun 27, 2011 | Dryers
I Have a kenmore 80 series dryer and have to replace the heating element where is it located and if possible do yall have a picture showing where it is located
you have to take apart the whole dryer i can post some pictures but its pretty easy to dismantle first unplugg unit open the door there should be two to four screws holding the top down should be a phillips type screw. lift top back inside unit ther are screws that hold on the front face must use a #2 phillips screwdriver one to two screw on each side after removing screws tilt from the top towards you then lift up there are two tabs that it slides into at bottom of front . there are some wires that you can unplugg but label them with white masking tape on each end like 1,1 2,2 3,3 use needle nose to pull off spade conector that whats on the end of the wire looks flatt. they got to the switch on the door . now you need to go to the back and open the small acess panel you can see the belt tensioning device push up of pull down to release tension then you should be able to go to the front and remove the drum and you will see the coil on the back of the dryer on the back of drum is a thimble that the drum rides on clean it well . you might notice that the coils have porclin sockets that the the coil is fed through the new replacment coil will have replacment peices to replace the ones that got burnt up. there are four screws that hold on the back pannel and a few heat sensors you can get a pre strung coil witch is the whole back panel but way more expensive. i thing th replacment coil is like 80 dollars and the pre strung coil is like 160 and up. if you need any more info let me know love to hear feed back to improve instructions
Apr 13, 2011 | Kenmore 63942 Dryer
Where is the heating element and how do you get to it on model DDE7207SBLWW
you first remove the control panel and remove the top cover,then 2 screws hold the front cover on,remove wires to door switch and remove front cover including the door,then the back of the unit where the drum bearing comes out the back remove static strap,then the "C" clip that holds the drum from coming out then pull drum out front and the element is behind the drum and back panel,its round & you can restring a new element i n the round element housing or purchase an entirely completely strung element its cheaper to string it yourself that buy it complete,then reverse dis-assembly to put it all back together
Jan 01, 2011 | GE Dryers
The drum goes round but there's no heat.
there is a heating element on the back wall and it looks like a spring closer on a screen door it is kinda flimsy and bends and warps as it cools and heats and sometimes it will rub on the drum or the back wall it shorts out and breaks a new coil costs around 80 $ takes a while to string through the ceramic holders you get some replacement holders to replace cracked or damaged ones with new coil. you can buy one pre strung it will cost allot more not an easy task for a first timer.
Jan 15, 2010 | Dryers
How to connect the lights on a 3 section pre lit christmas tree
Did you plug one section of the tree back into itself?
Dec 06, 2009 | Electrical Supplies
I had my leaf blower re strung and the cord does not go back in place after you pull it
It looks like the recoil spring is broken or not anchored properly.
Oct 08, 2009 | Yard Man Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
