Question about Hoover Vacuums
Wiring diagram Hoover spin scrub - Hoover Vacuums
    Guru:
  • 794 Answers
Hi Bill.
Try this link
www.manualslib.com
Posted on Dec 02, 2017
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
SOURCE: HOOVER STEAM VAC SPIN SCRUB
Cannot hook the upholstery cleaner into slot..lost manual in fire
Posted on Aug 02, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Posted on Sep 01, 2008
SOURCE: attach upholstery hose
Go to www.Hoover.com. Click on Carpet Cleaners. Click on Steam Vac All Terrain. Click on Learn more. Then click on Download the manual in pdf. The manual explains all.
Posted on Feb 07, 2009
SOURCE: My Hoover steam vac spin scrub model 4060-900 brushes are not spinning and I have lost the manual. Any ideas. Thanks. bushteachers@yahoo.com
The problem I found with one a neighbor was tossing out is the bearings in the part that drives the brushes were stuck. Lubing them up solved the problem, but took a bit of work to get into. This also provides a good chance to clean the crud out of bits that usually don't get much attention. I found mine clogged with a fair amount of pet hair.
You'll need a Phillips & Flat Screwdriver, some light machine (3-in-1) oil or Lithium (white) grease, and a lot of patience. Having a pan or something handy to keep all the little bits organized would help.
First remove both the soap & recovery tanks, they'll just get in the way & are designed to be easily removed & replaced for filing/dumping. Be sure to fold the "wings" for the recovery tank in or they'll foul removing the cover later (as will the brush speed button).
The tricky part is getting the Brush Speed knob off. It's held on only by friction, but can be tough to pull for without breaking the plastic stick it's pushed onto.
Remove the brushes. There are 4 blocks between the outer & next in rollers. Put the flat screwdriver between the gray & clear plastic, pushing gently toward the brushes. This pushes a wedge away far enough from a hole in the gray plastic to "unhook" the brush housing from the main body. Once all 4 are clear, the brush assembly should pull out easily.
Remove the 2 big screws in front of the brushes and the one at the back of the clear plastic front of the vacuum bit. The small ones at the extreme front corners hold on the clear plastic front, and can be removed if you want to clean out the vacuum channel, but are not necessary to remove to remove the top.
Toward the back sides of the top are 2 slots that hold this part on. Once the front screws are removed & the front is loose, push the side in gently & you should be able to lift the back of the cover. Push in lift both side, the top should pop right off.
Now I have the top off, holding 2 black & 1 silver long screw. In the center-front of the new-exposed guts is a box with a round top & a cone at the front with 2 screws.
This is the Brush Motor Assembly, and it's actually vacuum-powered. Remove the 2 screws holding down the from, then look for 2 large holes on the bottom of the unit behind the black "squirter bar".
There's very long screws at the bottom of these holes that also hold down the brush motor.Once the 2 bottoms screws have been fully loosened & the top-front screws removed, the brush motor should pull up easily.
On the right is a square port, in front the the brush speed stick (where the gray button pops onto). on the left is a gray & black hose, these should pull off easily, but may have some liquid in them.
Pull out the brush motor & set it on a convenient spill-resistant work surface upside-down. You should see the square-hole drice for the brushes, a gray piece of plastic, & a cresent-shaped hole.
The port at the front & hole on bottom provide an air path for the vacuum to poll air through this assembly & spin the brushes. You should see 2 screws at the back of the motor & 2 more at the bottom of holes surrounded by the gray plastic. Remove all 4 screws.
You can now pull off the bottom cover with the gray plastic. Front to back you should see the brush drive gear, an intermidiate gear, ant one of the bearings for the fan that drives the whole thing. pulling out the bearing & gears to clean out this area & lube up the gears with some Lithium Grease helps, as well as making sure the bearing is well lubed with 3-in-1 oil and/or lithium grease.
The top is held on at this point with 4 platic clips. The top doesn't need to be removed unless you *really* have to see the fan. The clips can be broken off if one is not careful, and there's nothing in there to be lubed. Best to leave it as-is.
At the top of the driveshaft is a second sealed bearing. I couldn't figure out how to get it out without braking it, lube this one in place. The bearings are supposed to be sealed, so removing the black "washer" from the bearing is done completely at your own risk. I just put some oil on there, spun it to work it in, then repeated with the white grease.
Replace the intermediate gear, the brush drive gear, then the lower sealed bearing in that order. You can spin the gears to ensure they're spinning well. Mine was OK, but after a bit of use worked the grease in & the brushes really started spinning.
Keep in mind everything here except the screws is plastic, be creful to get a snug fit with the screws without overtightening. "Gorilla-ing" the screws will just break the plastic & make the whole adventure an exercise in frustration.
Reattach the bottom plate with all 4 screws, 2 in the holes in the gray plastic, 2 in the back.
Reattach the gray & balck hoses to the left side of the brush drive. They're 2 different sizes, so there's only 1 place the smaller hose will fit easily. Place the assembly back in the machine & replace the 2 screws in the front.
Flip the machine up so you can put the 2 really long screws back into the underside of the brush drive. There's 2 guide slots on either side, make sure the brush with the indicator wheel on top goes into the big hole on the right. You may need to spin the brushes a bit to get the center squure stick to line up with the hole in the drive gear. The brushes should pop back in easily if everything's lined up right.
Put the top cover on, making sure the Brush Speed stick & center screwhole line up, as well as the back sides snap into place.
Screw down the top, then flip the unit up so you can snap the bottom-front of the top over the gray wedges on the front, then screw into place.
Replace the Recovery Tank, fill & replace the solution tank, and test-drive.
Vanger Chevane.
Posted on May 27, 2009
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
Does the Hoover F5835-900 have spin scrub brushes?
No. The F5893-900 has a brush but it is just a straight brush and does not spin.
Jul 18, 2010 | Hoover F5835900 Upright Steam Vacuum
Spin-scrub brushes do not spin
hello. there is a little window by the brush control. if you open it up, you can see that there is maybe some lint covering it. scrape that off, and try again. make sure your lever is set to brushes and realease the handle release. if this doesn't work, then you probably have a problem with your gear box. this can only be serviced at a repair shop. I hope this helps. Let me know! Thanks, Renevacdoc
Jul 23, 2009 | Hoover F7431-900 SteamVac Vacuum
My hoover spin scrub machine has stopped scrubbing. It still dispenses and pulls up the water, but the brushes don't move. I've checked the on off button for brush control and cycled it to off and back on,...
There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
Jul 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Do not know how to use Hoover Steam Vac Spin Scrub
Hoovers website, Hoover.com has them free to print.
Jun 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40488&thid=640907
Posted by mid-nite on Jun 02, 2008
My aunt lost the instructions to her steam vac, and she never got the chance to read them. Do you know how to operate it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac F5914-900 Spin Scrub Upright. The best thing to get an owners manual is to download the owner’s manual from the Hoover website or to call your local vac dealer or to call the Hoover Factory / Manufacturer to have them send you out in the mail a new owner’s manual for the model you have listed above . the phone 3 are listed below:
. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Jan 13, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Jun 16, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
