Question about Brother SX-4000 Typewriter
What is a ribbon for a electronic typewriter?
What does a ribbon mean ?? for electronic typewriter someone help!
    President:
  • 566 Answers
A printer ribbon is an inked strip of tissue or other material necessary for any typewritter to print.
In the case of your machine, this ribbon comes inside a cartidge or cassette that looks like those in the image in this link:
http://209.85.229.132/search?q=cache:xpfM5sM-mZwJ:www.databazaar.com/Inkjet_Cartridge/Catalog/SX4000_5167.html+brother+sx-4000+ink+ribbon&cd=1&hl=pt-PT&ct=clnk&gl=pt
To learn more about your machine, you can download de User Manual from here:
http://www.manualnguide.com/manual-get/11878/
Posted on Jul 30, 2009
Smith Corona-Model5 5P uses H ribbon. Spellright-correcting. Dictionary. Needa manual and ribbons.If you can help call 423-344-3516.
Smith Corona 5p Series Electronic Typewriter Parts ' Model ...
www.searspartsdirect.com/partsdirect/part.../Smith-corona.../0544000
Shop for Smith corona Smith Corona 5p Series Electronic Typewriter repair parts for model 335DLE(5ADF) at Sears PartsDirect. Find parts, manuals & diagrams ...
Mar 05, 2015 | Smith Office Equipment & Supplies
Typewriter beeps incessantly, does not respond to input
First try a little WD40 on the shaft thatb the carrier slides on and look for debris in the carrier movement area,
DickyO
Nov 13, 2013 | Swintec 7000 Typewriter
My Canon QS310 electronic typewriter ribbon is always out-of-stock in our country. What other typewriter ribbons (brand/models) that are compatible with Canon QS310?
If you had posted what Country you are located in, I could have ran a search to locate someone local to you that has this product in stock. I am located in California. I could give you information on compatible ribbons which are available in my area, but they may not be available in yours and that would not solve your problem.
I would suggest that you stick with the ribbon that is made for your typewriter if at all possible? If you are unable to locate stock in your Country, try ordering the ribbons online instead.
The ribbons are available at Office Depot. They sell the product online and have your ribbon in stock. Here is a link to your ribbon on their website:
http://www.officedepot.com/a/products/914465/Canon-Model-AP11-Correctable-Film-Typewriter/
Here is a link to a website that sells both the generic and brand name ribbon for your typewriter:
http://www.fjaproducts.com/SearchMe/Department8640.asp
I hope this helps? Good luck!
Jul 07, 2011 | Canon Office Equipment & Supplies
Ribbbon won't turn on IBM Electronic 50 typewriter.
I'm guessing you have a Wheelwriter not a memory writer 50..
Try a little WD40 on the ribbon feed motor and feed mech just under the R. rear of the ribbon deck. Also check the plug to that motor I have had them come out. If these don't work revove the ribbon, mark the black gear that feeds the ribbon with a dab of white out and see if it turns. If not you will need a tech.
DickyO
Feb 19, 2010 | Lexmark Wheelwriter 15 Series II...
How do i reset the wheel on a smith corona sl460 electronic typewriter? the correction ribbon keeps coming out of place
The typewriter has a spring at one spool to keep the correction ribbon taut. If that spring is broken or out of place, the ribbon will always get in the way of the wheel.
If both ribbons are correctly set tight between the wheel and the paper, the typewriter will reset the wheel at power-on.
Some models reset the wheel every time you close the cover. You can see and hear it if it does.
Feb 16, 2010 | Smith Corona Office Equipment & Supplies
I have an Olympia Electronic Compact. When I turn it on, it just beeps very fast. Nothing works? I love this typewriter, please help!!!!
I have the same typewriter. If I remember correctly, beeping very fast means there is a problem with the printer wheel. You might try (with the typewriter off) pulling back the wheel, reinserting the wheel, and turning on the typewriter. If that doesn't work, get another wheel (they're cheap online if you buy a Swintec wheel rather than an Olympia wheel - same goes for ribbons). The only other thing I can think is that the ribbon is out, needs reinserted, or there is no correction tape in the machine. But I think it has something to do with a broken or misplaced wheel.
Feb 02, 2010 | Olympia Office Equipment & Supplies
Ribbons and manual for Olivetti ET Personal 55 typewriter
The ribbons are available in the USA GENERAL RIBBON #T381 or Nukote B136 L/O G.R. #T376 Instruction book not likely. I hope you can find them a little closer to home.
DickyO
Oct 29, 2009 | Olivetti Office Equipment & Supplies
Olivetti 901D electronic typewriter
There are some rubber sleves that the ribbon sits on when it is in the lowered position they get very gooey and stop the ribbon from lifting if tou find them and remove them it should work.
DickyO
Mar 28, 2008 | Office Equipment & Supplies
Brother AX-450 Electronic typewriter
Hellooo.
2 thing come to mind you may check.
First check the ribbon cartridge to see if it is empty..These are usually a one time ribbon...and has to be replaced when empty.
2nd make sure the cartridge is snapped in properly and seated, and also the printwheel lever must be snapped (pushed forward) in order for everything to be aligned. if the typewriter has a correction tape (white or clear) make sure it is not interfering with the ribbon.
Lastly the ribbon drive may be broken or out of adjustment. a minor repair.
Hope this helps...
Squipps
Jan 08, 2008 | Brother EM-430 Typewriter
Brother SX-4000 Typewriter Logo
97 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
