Question about Motorola T6510 XLR Talkabout Two-Way Radios :
Roger beep How do you mute the roger beep?
  • uter Jan 17, 2008
    Need Instructions
    Scholar:
  • 130 Answers
I'm pretty sure you can't mute it, but I think you can change it in the settings.
Posted on Dec 04, 2007
  • Ryan RIopel
    Ryan RIopel Jan 27, 2008
    Try this.
    To eliminate the roger beep -- power down, press and hold the "+" key, power
    on, and then release the key.
    To eliminate beeps while going through menus -- power down, press and hold,
    the "-" key, power on, and then release the key.
    Please rate!
Can I turn off the beep on the cxt195?
You mean the "roger beep"? You can try the steps below from this site>>http://science.opposingviews.com/turn-roger-beep-off-motorola-walkie-talkie-10001.html
Step 1
Turn the Motorola Talkabout two-way radio on by pressing the "Power" button.
Step 2
Hold down the "Menu" button for several seconds until an icon appears on the screen. "On/Off" begins to flash on the screen.
Step 3
Press the "Minus" button to turn the "Roger" beep off. If you want to turn it back on, press the "Plus" button.
Step 4
Tap the "PTT" button to save the change. You may also press "Menu" to save the change and completely exit Menu mode
Hope it helps...
Dec 03, 2014 | Radio Communications
One of my walky talkys(motorola T4500) makes an extra beeping noise whenever i turn it on. This noise also shortens up what people are saying before they finish talking. How do I fix that?
What you might be experiencing is the Talk Confirmation Tone aka Roger Beep. I have looked through the T4500 manual and do not see any instructions for turning it off, just that it is listed as a feature. However, something you might try is holding in the + (plus) button while turning on the radio and see if it disables the feature. This method is used on many of the other TalkAbout models.
If it is not the Roger Beep, it could be a low battery beep. But from your explanation it sounds more like a Roger Beep.
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
Best regards.
Aug 25, 2011 | Motorola Talkabout T4500 (7 Channels)...
Galaxy saturn ...roger beep just chirps no beep
either a capacitor has changed value or someone changed it. with the board facing you --front right where the mic connector would be on a mobile unit is were the roger beep components are. make sure none are blown or no resistors are burnt. We can restore it back to a factory beep if you would like.
Dec 17, 2010 | Radio Communications
I would like to turn off the roger beep on my BellSouth model 229
You need to open the radio and look for the roger beep board. It should be a white wire going to one of the pins on the mic jack. If you interupt that wire the tone will not play. You can either disconnect it, or put a switch on it so you can turn it on and off.
Oct 04, 2009 | Superstar SS-148DX 40-Channels Base CB...
How do you go to silent mode?
There are two different kinds of beeps you can control, the "roger" beep and the "button" beeps. Below is an excerpt from the owners manual explaining the simple procedure.
“Roger” Beeps/Talk Confirmation Tone
When you turn this feature On, your two-way radio transmits a unique tone when
you finish transmitting. It’s like saying “Roger” or “Over” and lets others know
you have finished talking. If the person you are talking to does not hear the talk
confirmation tone, you can enable it by pressing and holding + (plus) as you turn On
your radio. Now, whenever you release the PTT, you let your friends know you have
finished talking by transmitting a “Roger” Beep tone. “Roger” Beeps will be
disabled as the Default Setting.
Note: To toggle the Talk Confirmation Tone feature, turn your radio Off and then
back On while pressing and holding + (plus) .
Button Beeps
Every time you press a button on the front of your radio, it beeps unless you turn
Button Beeps Off. To turn Button Beeps Off, turn your radio On while you press - (minus) and
hold . To turn Button Beeps back On, turn the radio Off and then back On again
while you press and hold the - (minus) . On is the Default setting.
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T7100_User_Manual_E.pdf
17
Nov 28, 2008 | Motorola T7100 2-Way Radio
Turning off roger beep
Press and hold the plus (+) button while turning on the radio.
You can find the instructions on page 24 of the user manual: http://www.giantintl.com/RadioPDFs/manuals/T6500.pdf
Nov 20, 2008 | Motorola Talkabout T6550 (7 Channels)...
Motorola radius sp50 "roger beep"
The radio will need to be reprogrammed using the radio service software for the SP50 radio.
Jul 05, 2008 | Motorola Talkabout FR50 (14 Channels)...
Roger Beep
Hi Helen,
On most Motorola radios, to remove the roger beep, while powered on, you need to press the menu button until the Roger Beep indicator in the display starts to flash. Press on the + or - to change status. Press on the PTT to save and exit.
Hope this be of some help. Pls post back if it worked or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Motorola TalkAbout T6530R (14 Channels)...
Roger tone
Hi, To remove the "Roger Beep", power off the radio. Press on the "+" button, without letting go, power on the radio. Release the button. The "Roger Beep" should be gone by now. To activate, do the same. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | Motorola TalkAbout T6530R (14 Channels)...
Motorola T6510 XLR Talkabout Two-Way Radios : Logo
216 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
