My dvd drive doesn't open and it doesn't read disks
  • 3 more comments
  • chris1073 Jul 29, 2009
    I MEAN i can open it using the emergency eject hole and it still doesn't read the dvd-r/cd-roms
    acer
    acer extensa
  • chris1073 Jul 30, 2009
    what is the registry
  • Bobcatflusa May 11, 2010
    how can it read a disk if it doesn't open to put one in? How about giving the machine type.
  • 66 Answers
Well you must try to delete upper filter and lower filter from the registry and path to upper filter and lower filters are
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Posted on Jul 30, 2009
  • 57 Answers
Sounds like the drive is not being recognized by windows. Open My Computer or Computer and see if the drive shows up in the window. Then get into the device manager and see if it is there with no x's or circles around it. If it is not in device manager then try searching for new hardware and see if it finds it. If it is there then remove the drivers and reinstall them.
If it is not there then shutdown and reboot and get into the bios screen and see if the bios recognizes the drive. If it doesn't then the drive is bad or needs to be reseated. If you need more help then give the model number so I can find the user manual from the Acer web site
  • 596 Answers
Are you able to see your drive from My computer area? If so, you may need to update the drivers for your particular brand pc/DVD-ROM. If you need to open the drive to get media out of it, you can use a paper clip, stick it into the small opening on the front of the DVD-ROM and gently puch. The drive should open.
Good Luck.
C2Solutions
2 Suggested Answers
  • 357 Answers
SOURCE: DVD drive won't read original
First are you CERTAIN the computer you are using the dvd in is capeable of reading dvd discs? If so I'd recomend purchasing a cd/dvd cleaner (available online and in most audio shops) and a CD Lense cleaner.
This should cure your problrm, unless it's one of the first signs of the laser wearing out, in which case a replacement drive is required
Posted on Jan 16, 2011
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
Sep 22, 2012 | HP Pavilion dv6775us Notebook
My dvd drive doesn't work
If it happens for only one particular disk:
Bring that disk to a game store like Gamestop or Rock30 Games and have them professionally clean the disk for a couple bucks.
If it happens for all disks:
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Jul 31, 2012 | Acer Aspire 5738Z Drivers Recovery Restore...
My Dell optiplex 740 DVD/CD Rom drive does not read any disks.
You likely have a dirty or malfunctioning laser in your DVD drive. You can try cleaning the laser with a cleaning kit or open up the DVD drive and clean it manually with Isopropyl Alcohol. There is also a chance that drive motor is failing or the drive belt is stretched (Drive will likely make noise if this is the case). Parts can be sourced on eBay if necessary.
In my opinion. Just ditch the drive and buy a new one. It will cost $20-$30 and take 15-20 minutes to install. You could spend hours attempting to repair it and there is no guarantee you will be successful. These things are basically disposable now. If you want to open it up first then by all means give it a shot. You have nothing to lose because it already doesn't work and you'll at least learn something new.
Try cleaning the lens with a kit or alcohol and a cotton swab first. If that doesn't work, just buy a new one. It's much easier and possibly cheaper too.
Jul 26, 2012 | Computers & Internet
Toshiba satellite l505-s6946 not reading disks
Jun 30, 2012 | Toshiba Computers & Internet
Computer is not reading the installation disk
By installation Disk do you mean the CD/DVD-ROM? If yes
Check to see if the drive's LED flashes when the system is trying to boot. If it doesn't, open the system and make sure all the cables to the CD/DVD- ROM is properly connected and to the right slots. If the cables are properly connect and the CD/DVD- ROM is still not working replace the CD/DVD-ROM.
However, if its that the system could not install a particular program, make sure the installation files are complete and try again. If its a downloaded program, verify the completeness of the file downloaded and try reinstalling the program.
Feb 13, 2012 | Peachtree Software Computers & Internet
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
My dvd drive on my laptop will not read all disks
check your drive spesc - it can't not compatible with some disks, there are many formats: DVD-R, DRD+R, DVD-RW, DVD+RW.
some disk recoder applications can leave open sessions and it makes disk readable only on the same drive where it was burnt
Nov 21, 2009 | Computers & Internet
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Dmr-es10 dvd recorder panasonic
does it record?We have noticed that these problem is occured by dirt on optical .First you have to clean optical lens .take cotton sworb and open the dvd-ram assy ,open top cover and claen leser.If problem still persist than only solution is to change dvd-ram drive thats optical assy.
Dec 18, 2007 | Panasonic DMR-ES10 DVD Recorder
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Computers & Internet Logo
358 people viewed this question
David Payne
David Payne
