Question about GE Profile Spacemaker Over-the-Range Microwave
How do I replace the door handle? I purchased a new one but dont know what to disassemble to access the mounting.
  • 4 more comments
  • arifali511 Jul 29, 2009
    There are indeed no visible screws holding the door together. INstead:
    - On one side are folded sheet metal tabs which are easy to open / fold
    - One another side there is a folded sheet metal edge which is hard to old without losing the uniformity of the metal.
    - One side has tabs sinilar to the first ones listed above but thatare folded 180 degrees and inserted into slots making it impossble to unfold or remove them until the other three edges are loosened.
    - Last side that looks like it has a lip that is also folded into a slot - i.e., dont know how to get it out.
    any more ideas?
    Actually I believe this is the correct diagram
    I just didn't find it particularly helpful as to how to disassemble the front panel. I assume I can jimmy the thing off, but I am not sure it would look the same when I reassembled it...
  • arifali511 Jul 30, 2009
    I'm not sure how you managed to find my question without noticing that my question relates to a GE Profile SpaceMaker 2.0 Microwave Oven. Unfortunately your solution will not work for me.
    Interesting...I will look at this later today. At first glance, it is unclear how I would be able to remove that panel. But, since I've been focusing on how to get the front panel loose, your input sounds promising since it is a different angle than I'd been considering. I'll try it and let you know.
    Thanks,
    The microwave in the video is much simpler than mine. However, I have one other solution that has been suggested. If theirs doesn't work. I'll see if I can use yours
  • arifali511 Jul 31, 2009
    Bravo! it was a piece of cake!!
    Thank you very much!!
    President:
  • 2,185 Answers
Try this:
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
http://www.fixya.com/support/t2211022-our_handle_broke_off_our_ge_profile
Posted on Jul 30, 2009
  • 10,865 Answers
Hi there. THis should help:
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 31, 2009
    President:
  • 2,777 Answers
What is the make / model of the unit? I can help you out just need this info.
Thanks
Tim
    President:
  • 1,714 Answers
Watch this video;
  • 1 more comment
  • Craig Butler
    Craig Butler Jul 30, 2009
    Ok, now i know what you were looking for. Try this video, I think it may help you!
  • Craig Butler
    This is the right video this time, check this on:
  • Craig Butler
    here you go
  • 11,896 Answers
There should be 4 screws holding the door together, remove screws, pull apart panels, and there should be 2 more screws holding on handle
Posted on Jul 29, 2009
  • Nate Stansfield
    Nate Stansfield Jul 29, 2009
    I understand. You have that type. I don't know why they sold you just a handle instead of the new door. Not all handles are replaceable.
    Although, some handles can be pulled apart and there are screws on the undereath part of it.
  • Nate Stansfield
    How to replace the door handle
    First, click here to see the diagram. #11 hooks on to #9. Get a kitchen knife or a putty knife and slowly pull #11 off the door. Use this thread for more help. Once #11 is off, you will see the handle screws and will be able to replace the handle at that point.
    Model JVM1339BW03
    Here are the break down diagrams for the GE microwave
Handle broke off, model # khhs179Lss-4, wna to
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
If you have not purchased a new door handle yet, the part number is 8205431 (White), 8205433 (Black), 8205432 (Biscuit) or 8185456 (Stainless). A new one can be purchased at pcappliancerepair.com for about $40-46. Make sure you order using the correct part number to ensure you get the right color.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 16, 2009 | Microwave Ovens
Broken handle on Spacemaker microwave
The handle can be replaced without replacing the entire door, or oven. The part number is WB15X1309 and can be purchased at pcappliancerepair.com for about $45. Due to the age of your oven, I could only find it at a couple of web sites, and this was the cheapest price I could find for you.
Sep 08, 2009 | KitchenAid KHMS147 Microwave Oven
How do i replace the door handle.
If you have questions about this repair, please let me know. I hope this helps you.
Aug 10, 2009 | Microwave Ovens
How to replace door handle?
The door handle can easily be replaced. This is a common problem with microwave oven doors.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Jul 30, 2009 | Microwave Ovens
I NEED TO REPLACE PART 83242. HOW DO I REMOVE
I do not know what part #83242 is. A search of several reliable parts web sources, yielded no positive results. So, I'm guessing this may be a door handle(?). If so, to access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you need to remove the entire door, simply open it all the way and lift at the hinges. The door will lift off the hinge mounts. You may wish to remove the door for an easier means of working on it. Especially, if the microwave is mounted above your range.
If you have questions, please let me know. If this is not what you are needing assistance with, please post back with the name of the part you are trying to replace. I hope you find this information helpful.
Jul 10, 2009 | Sharp R-1480 Microwave Oven
How to replace the door handle on a mod. MH 1170XSY-0 mico wave
If you have questions, please let me know. I hope you find this information helpful.
Jul 09, 2009 | Whirlpool MH1170XS Microwave Oven
Need to replace the handle I have the part but how do i desassemble the door properly
Jun 03, 2009 | Microwave Ovens
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
Check out this door frame diagram, specifically number 1805. It clips on to the door frame. Remove it using a dull table knife or something similar (be careful not to scratch or break anything). You will then have access to the bottom screw.
Mar 18, 2008 | GE Advantium SCA1000H Convection /...
GE Profile Spacemaker Over-the-Range Microwave Logo
1,096 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
