Question about Coby Audio Players & Recorders
I want to know what an User EQ is? - Coby Audio Players & Recorders
  • 38 Answers
Most Audio devices will allow you to adjust how the music is played. an EQ is just something that can increase or decrease audio Frequencies. there are usually preset EQ levels that will make Jazz, Classical, Pop music sound better. this is done by increasing the High notes or increasing the low notes to give you more of a bass sound. User EQ settings allow you to manage the frequencies more to your liking. If you want to here the high notes better or adjust the middle to hear the vocals better then you can increase those levels. Or if you love your bass sounds then you would increase the lower frequencies to give your music more boom.
Posted on Jul 30, 2009
I have a jvc kdhdr50......and I'm wondering how to adjust the bass and treble also how to turn the loudness on
This is discussed on page 26 of manual. Press and hold MENU and select USER for EQ. Under EQ you will have options to adjust SUB BASS, BASS, MID BASS, ULTRA HIGH, HIGH, MID HIGH, AND MID
Aug 10, 2014 | Car Audio & Video
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
I want to plug a microphone in channel one, send it to a EQ and delay for processing and return it back to channel one. I appreciate any assistance
Look in your user manual for how you "INSERT" an EQ at an input. The 1/4 inch TRS jacks on the back, lower row labeled "Insert" is where you use a TRS cable to aan EQ that has TRS INSERT jack. If your EQ doesn't have this, then you will need to find or make a "splitter" cable. The tip of the cable is the send to the EQ and the sleeve is the return signal after EQ.
Jun 04, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
Need help on setting custom EQ for my JVC KD R506 in car music system. m not able to find the settings. also any idea how to increase the bass effect from the speakers. can i connect a subwoofer without an...
Set your equalizer to you a V shape or U shape pattern, bass effect can only attain by adding a powered subwoofer, (amplifier and subwoofer). subwoofer without an amplifier doesn't sound good, your system doesn't have enough power to drive your subwoofer.
Jun 23, 2010 | Car Audio & Video
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Need help connecting my eq to my system.
You will want to connect all of your devices to the pre-amp or receiver, then connect the outputs of your pre-amp/receiver to the inputs of the EQ. Then connect the outputs of the EQ to the inputs on the amplifier or receiver. If you give me some model numbers, I would be able to tell you exactly which cables go where.
Mar 31, 2009 | Audio Players & Recorders
How do I connect a Marantz EQ 140 to a Marantz MR235 reciever through tape one (tape monitor) I am not confident that I have it hooked up correctly because I get music when the eq and tape monitor are on...
Dear driver800,
Don't you just love it when when someone who knows less than you do tries to answer your question? Why is it people who know little waste everyone's time with suggestions like "read the book"
On the back of your Marantz MR-235 you will find the RCA phono jacks marked Tape 1 Monitor Output these connect to the jacks labeled input on your EQ 140. The corresponding jacks labeled Tape 1 Monitor Input connect to the jacks labeled output on the EQ 140.
QED
Russ
Jul 28, 2008 | Marantz Audio Players & Recorders
JVC KDG 340 Car stero
SOUNDS SETTINGS....OPRIME EL BOTON Q DICE EQ...EN LA PARTE SUPERIOR DERECHA....Y ADJUST BASS....PRIMERO OPRIMES EQ.....SELECCIONAS USER..Y LUEGO OPRIMES LOS BOTONES DE DIRECCION HACIA ARRIBA Y HACIA ABAJO..Y AHI SE LO PUEDES AJUSTAR
angel_lk2@hotmail.com
Mar 17, 2008 | Audio Players & Recorders
Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
Feb 10, 2007 | Yamaha HTR-5860 Receiver
74 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
