Question about LG KC910 Renoir Cell Phone
Can i use my renoir as a modem for my mac - LG KC910 Renoir Cell Phone
How to use telephone modem in mac ? Can you guide me through step by step to use telephone modem in macbook ?
Unfortunately dial-up modems are no longer made by Apple. However, there are still a number of dial-up modems available from third parties - Zoom and Belkin still make USB-based dialup modems, I believe, and Apple did at one point make a modem that may still be available through third-party retailers such as Amazon or Ebay.
Whichever you choose, install the software that it comes with and then follow these instructions:
  1. From the Apple menu, choose System Preferences.
  2. From the View menu, choose Network.
  3. Choose "Internal Modem" from the Show pop-up menu (or the "Configure" pop-up menu prior to Mac OS X v10.1).
    If your computer does not have a built-in modem, select your external modem.
  4. Mac OS X v10.5 or later: From the Configuration pop-up menu, choose Add Configuration.
    Mac OS X 10.4.x or earlier: Click the PPP tab.
  5. Enter your information into the relevant fields. Your username goes in the Account Name field, for example. If you want to copy this connection information to other user accounts on this computer, select "Save password".
  6. You should now be able to connect. If you need to configure DNS servers or other advanced settings, continue to the next step.
  7. Mac OS X v10.5 or later: Click the Advanced button, then click the DNS tab.
    Mac OS X v10.4 or earlier: Click the TCP/IP tab. Choose either PPP or Manually from the Configure pop-up menu, as instructed by your Internet service provider. If configuring manually, type the IP address in the matching field.
  8. Type the DNS server addresses in their field if necessary (click the "+" button first in Mac OS X v10.5 or later).
  9. Click OK.
  10. Click Apply (or Apply Now for Mac OS X v10.4 or earlier).
Jun 24, 2011 | Apple 133 MacBook Intel Core 2 Duo 24GHz...
I connected WRT54GL router to Motorola modem per linksys instructions. the router is not able to connect to the internet. please advise
This is most likely due to the Motorola modem still having the Media Access Control (MAC) address of the device that was previously connected the modem in NVRAM.
In order to clear this old MAC address, the easiest thing to do is to unplug the power cable from the modem for 15 to 20 minutes. This allows the NVRAM in the modem to clear and makes it able to accept the new MAC address of the router.
After the modem has been unplugged from the power for 15 to 20 minutes, plug the Ethernet cable of the router into the modem and plug the power cord back in to the modem. After the modem syncs back up to the network, it should add the MAC address of the WRT54GL router to its NVRAM and assign it an IP address. This should allow the router to connect your systems to the Internet.
Dec 27, 2010 | Linksys Wireless-G WRT54GL Router
KC910 Renoir Cell Phone: when the Renoir says others in the phone memory wh...
in a renoir cellphone you can use the handset (phone memory) ,USIM (SIM Card) or both it displays files on a certain memory if its on handset it displays files ONLY on the handset
May 16, 2010 | LG KC910 Renoir Cell Phone
I'm trying to use my KC910 as USB tethered modem
I hope once you are connected you will pay the bills or maybe your employer will foot the bill---lucky man
May 11, 2010 | LG KC910 Renoir Cell Phone
Need new ip and mac adress for sb5100 motorola for southwest
To get new IP unplugg power for 1 minutes the plug the power back in. MAC address is a unique identifier specific to that modem. To get a new MAC address you will have to buy a new modem.
Sep 13, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Watching Youtube on my LG Renoir Mobile
You can watch YouTube mobile directly from your Renoir - m.youtube.com
We hope this helps!
Jun 28, 2009 | LG KC910 Renoir Cell Phone
USB reads wireless modem, software doesn't!
mac doesn't support any data card till date so this is not working . if you want to connect it install windows using bootcamp then your problem will be solved. if something importent rate this article
May 09, 2009 | Apple iBook G4 Mac Notebook
WI-FI connection problem LG KC910 mobile phone to apple notebook
wep is for wireless network turn off airport need manual network setup , look under network prefrences n change settings,
actionman
Jan 31, 2009 | Apple MacBook PC Notebook
No internet when using router
Your modem has already registered itself with the MAC address of your computer, so it doesn't recognize the MAC of your router. In cases like this you have two options:
  1. Configure your router to clone the MAC of your computer
  2. Connect the router to your modem and do a soft reset so the modem registers itself with the MAC of your router.
Clone MAC - Go to your routers Admin web interface and on the main page you should see the "Router MAC Address" section at the bottom. Select "Use Computer MAC Address" and click "Apply" and your router should reboot and you'll be back in business.
Soft Reset
- Plug the modem into the router via the ethernet cable then do a soft reset.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the Reset EMR button on the modem
  4. plug back in the power
  5. count to 30 while holding the Reset EMR button (the modem should be blinking a lot)
  6. release the Reset EMR button and see what happens.
Jul 07, 2008 | Computers & Internet
LG KC910 Renoir Cell Phone Logo
102 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
