Question about Poulan Garden
I have a Snapper Snap N Go S31sng it starts with difficulty but starts than it will not keep going. What could the problem be?
5 Suggested Answers
gisvc
  • 40 Answers
SOURCE: The edger does not start
HI, ALEX
1st thing is to take the remaining gas out of the edger and wash out the tank with fresh new gasoline. it is most likely the problem is in the old fuel. it will in as little as 3 weeks start to varnish or seperate into less combustible properties and will smell a little sour or vinegar.since it was running at the end of last season i would replace the spark plug and refill with fresh gasoline. i would also add a additive seafoam acording to the bottles recommendation which is 1 0z per gallom\n of gasoline. it won't hurt to add this to what ever gasoling can you are using because this is recommended for all gasolineengines. give it a try and it should get you up and running. happy edging!
Posted on Mar 29, 2009
#1 Taper
  • 1040 Answers
SOURCE: My Snapper S31SNG will not start after replacing carb.
A short fuel line leading from the primer bulb should be placed just inside the tank. This line may be larger than the other fuel line depending on your trimmer, so make sure that you have the correct sizes. The small plastic piece goes at the end of the fuel line to prevent it from pulling out of the tank. It also serves as a overflow. Cut this line a little longer than you need it until you get it in the correct position. (Hint: You may want to taper the end of the lines before putting them in the holes, it makes it much easier to feed them into the hole, then square them up after they are in.) The other line goes to the bottom of your tank with a small filter at the end.
Posted on May 22, 2009
digritz
  • 530 Answers
SOURCE: Have a snapper snap n' go trimmer s31sng - One of
I am not really sure how many lines you replaced. But the fuel line layout on most types of trimmers, weed wackers and lawn mowers are pretty straight forward. There is usually a line inside the gas tank for connecting the fuel strainer\filter. Then a line from the bottom of the tank to the carburetor. This line may also have a fuel filter located on it. On more complicated equipment you may find a breather line that loops back to the carburetor.
Below are a couple of links that might be helpful. The first three are diagrams of a similar 31cc Snapper trimmer and links to other Snapper trimmers. The fourth is to the users manual for your trimmer.
Hope this helps.
http://www.partstree.com/parts/?lc=snapper&mn=311+31cc+Straight+Shaft+Trimmer+Series+1&dn=6600
http://www.partstree.com/parts/?lc=snapper&mn=310+31cc+Straight+Shaft+Trimmer+Series+0&dn=6597
http://www.partstree.com/parts/?lc=snapper&mh=19
http://dl.owneriq.net/a/a3fbde0d-dc76-4963-935f-821589699385.pdf
Posted on Sep 01, 2009
mec_ronnie
SOURCE: Need help reconnecting fuel lines
NEED TO PUT NEW FUEL LINES ON SX-135 TRIMMER? NEED TO KNOW HOW LONG FOR EACH ONE & WHERE THEY GO?
ADJUSTING AFTER INSTALLED?
Posted on Oct 19, 2009
How to start it
      Stand behind the lawn mower. Use one hand to hold the engine stop lever in the operating position. Use the other hand to hold the recoil starter handle. Slowly pull the recoil starter handle until resistance is felt, then pull quickly to start the push mower engine.
      How to Start a Lawn Mower ' Starting Snapper Mowers FAQ
      www.snapper.com/us/en/support/.../how-do-i-start-my-snapper-lawn-mowe...
    Feedback
    How to start the lawnmower - YouTube
    ? 2:54
    https://www.youtube.com/watch?v=QsRwZZwO4oc
    May 25, 2012 - Uploaded by iScaper1
    Tips on how to start a lawnmower. I asked my wife and boys today if they could start the lawnmower. One son ...
    How to Start a Push Lawn Mower: 7 Steps (with Pictures ...
    www.wikihow.com > ... > Lawn Care
    wikiHow... there's more to it than that, especially if you want it to keep running. Of course, how to start your individual lawn mower may vary according to what brand and...
Jan 12, 2016 | Garden
Why will my Snapper riding mower NOT go into gear? forward or reverse?
what kind of snapper... RER ( rear engine rider ) tractor style, model number will help greatly here because snapper has made mowers since the dawn of time !!!
Aug 23, 2014 | Snapper Garden
How to drain gas from snapper zerro turn mower
Take the fuel line loose at the petcock or filter. Should have a snap ring there.
Jan 08, 2013 | Simplicity Snapper Pro 36" Zero Turn Lawn...
Snapper Mower hard to start/run
the choke is controlled by a rod that goes to the muffler it's a open or closed thing see a lot more problems with dirty carbs and the needle valve seats swelling from the fuel
May 28, 2012 | Garden
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Sep 01, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Have a snapper snap n' go trimmer s31sng - One of the fuel lines or more were cracked and It quit running - replaced all fuel lines but don't think I reconnected them correctly. Do you have a diagram of...
Hope this helps.
Sep 01, 2009 | Troy Garden
Need carb screw settings
Hi try setting the screws at 1&1/2 turns out from the closed position and go from there.
Aug 30, 2009 | Garden
May 21, 2009 | Garden
HI, ALEX
Mar 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
223 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
