Question about Viper Vehicle Parts & Accessories
Ok I bought a 2010 ram.and i have found a viper remote 7752v in the.truck., the one that i found was wore out, i got another one and i have tried to pair it and tge alarm went off once , so i know all of it should work! Im wondering how i can tell if I have remote start.
    New Friend:
  • 36 Answers
First get a chevy then look under the stering column and if there is a few boxes there if there are then look up the model number and see how it works. i found a system but not a remote
Posted on Dec 14, 2017
  • 82 Answers
SOURCE: All of a sudden my alarm started going off and the only way to turn it off is to start up my truck. Well I tried but it won't start with the remote or the key. My truck battery is fine, I have an opti
There should be a Valet/emergency override switch, you must turn the key to the on position and switch the switch ... the LED should come on solid, try that, if no go .... Call the people who installed the system ... it is malfunctioning .... If you have RF key ... it may be being interfeared with buy the security override system that is required to remote start the car ...
Posted on Apr 30, 2009
deadrock69
SOURCE: Viper 5901 Starting issues
i need to adjust the time that it waits to start for my glow plugs in my 2001 ford excursion diesel 7.3. I need it to wait another 10 - 12 sec.
Posted on Jan 07, 2010
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
  • 1455 Answers
SOURCE: i lost my remote for my viper 350 hv,and when i
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Posted on Oct 08, 2010
logosc75
  • 625 Answers
SOURCE: I just received a brand
Try plugging the charger into an outlet then, plug the charger into the remote, remove, plug in, remove...Do this for approximately six(6) times or, until "charge" appears on the remote. When "charge" appears on the remote leave it pug up to complete charge.
Posted on Jul 17, 2011
My sst 7752v viper remote will not unlock my doors, it just beeps. I cant get into my truck without my remote... please help
how old is the remote is a question to consider. the batteries might just be too low to send a strong enough signal for the truck's transponder to receive. does the remote need to be coded to the truck if not more than likely its weak batteries. the LCD display doesn't need much power to light up, but the remote does to send the signal.
Aug 08, 2013 | 7752V Replacement Transmitter Supercode...
I need a charger for 7752v remote
you can charge it from your computer if you have a mini usb cable like one from a camera would work. Also if you have an old cell phone charger that has the mini usb connector on the end will work. The motorola driod x charger would be a perfect match. If you need to replace the battery because the remote will not turn on any more I replace the batteries on ebay search viper 7752 remote battery service. Hopefully this helps.
Feb 05, 2013 | Viper Televison & Video
Remote 7752v dead wont start
I replace the batteries in the remotes search ebay viper 7752 remote battery replacement.
Dec 02, 2012 | Viper 7752V
Viper 7752v frozen
If the battery is dead there is a guy on ebay that replaces them. He fixed my remote.
Nov 01, 2012 | Viper 7752V
How to set viper 7752v remote on vibrate
Press and hold the "f" button the remote for approx. 8 seconds. The screen will display remote setup. Press the Aux button to scroll up and the remote starter button to scroll down. Press and hold the "f" button to enter the selected feature, which would be page alert. When the option you want is displayed on the LCD screen (vibe,tone,both,off) press and hold the "f' to save. You can press lock or unlock at anytime to exit the remote programming.
You can also press "f" then lock or unlock to silent arm or disarm without going through the above programming procedure.
Aug 20, 2012 | 7752V Replacement Transmitter Supercode...
Need viper 7752v owners manual
The 7752V remote is compatible with five Viper systems. The owners manuals for each respective system can be downloaded via the following links:
5904
4704
5501
5901
5704
Nov 15, 2011 | Remote Start System
I just received a brand new viper 7752v remote and it will not power on even when plugged into the charger. I have tried to press the function key several times to reset it and nothing. Any Suggestions?
Jul 11, 2011 | 7752V Replacement Transmitter Supercode...
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Feb 08, 2011 | 7752V Replacement Transmitter Supercode...
Vehicle Parts & Accessories Logo
57 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
jason
Colin Stickland
Colin Stickland
Jim Goldsmith
Jim Goldsmith
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
