Question about Dell Inspiron 1521 Laptop
My cd/dvd drive is saying it is not installed as well as my volume
    Scholar:
  • 164 Answers
Look for drivers web site to down load for you pc
ore load on usb drive put back on your lap top
Sounds like you might have virus playing games witht your lap top.
Posted on Jul 29, 2009
D drive will not load some disc programs in to the computer
If you are saying D drive is your CD/VDVD drive? If you are installing from CD/DVD drive then suddenly stop the installation/setup/loading you must check your disc drive. To check your cd/dvd drive insert a cd or dvd cleaner and start cleaning most of the cleaner has a movie inside of the disc and run for about 10 minutes. Then try again installing/setup/loading the program to your computer. If its still the same, replace your CD/DVD drive with a new cd/dvd drive because your cd/dvd drive is need to be replace. Have a nice day
Jan 26, 2011 | Computers & Internet
Dvd drive not detected
Try unistalling the cd drive using your device manager. After removing it from there reboot and see if it is correctly identified and installed by Windows. If not you can manually install the driver or firmware from the drive manufacturers website. Hope this helps.
Jul 26, 2009 | IBM (33P3227) CD-RW/DVD-ROM (Combo) Burner
Volume icon in taskbar
You experience one of the following symptoms on a Windows XP-based computer:
* The Volume icon is not displayed in the notification area at the far right of the taskbar.
* When you try to add the volume control icon to the notification area, you receive the following error message: "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel. "
Therefore, you cannot start the Volume Control program and cannot adjust the volume and sound level settings of your computer.
There are two possible causes of this problem:
* The Volume icon has not been added to the notification area of your computer. (The Volume icon is not displayed automatically when you first install Windows XP.)
* The Sndvol32.exe file is damaged or missing.
Solution:
Method 1: Add the Volume icon
To add the Volume icon to the notification area of your computer, follow these steps:
1. Click Start, and then click Run.
2. Copy and paste or type the following command in the Open box, and then click OK:
mmsys.cpl
3. Click to select the Place volume icon in the taskbar check box.
4. Click OK.
If the Volume icon is displayed in the notification area of your computer, you are finished. If you cannot add the Volume icon or if you receive an error message when you try to add it, the Sndvol32.exe file might be damaged or missing. Go to method 2.
Method 2: Save a new copy of the Sndvol32.exe file on your hard disk
If the Sndvol32.exe file is damaged or missing, you must extract a new copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk.
Prerequisites
This method requires you to have your Windows XP installation CD.
To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer’s hard disk, follow these steps:
1. Insert the Windows XP CD into your computer's CD drive or DVD drive. Press and hold the SHIFT key as you insert the CD to prevent it from starting automatically.
2. Click Start, and then click Run.
3. Copy and paste or type the following command in the Open box, and then click OK:
cmd
The command prompt opens.
4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer’s CD drive is drive E, type the following, and then press ENTER:
e:
5. Copy and paste or type the following, and then press ENTER:
cd i386
6. Copy and paste or type the following, and then press ENTER:
expand sndvol32.ex_ system_root\system32\sndvol32.exe
Note: system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER:
expand sndvol32.ex_ c:\windows\system32\sndvol32.exe
Note There is a space between "ex_" and "c:\windows" in this command.
7. Type exit to exit the command prompt, and then press ENTER.
8. Verify that you can start Volume Control and that the Volume icon is displayed in the notification area (if you selected this option in method 1).
Hopefully the Volume icon is now displayed in the notification area.
Jul 18, 2009 | Computers & Internet
I have an erroe message I can't get rid of.
hey buddy this is the disc problem ...but some time dvd or cd drive can not read the disc properlly..and give u this erroe. that's mean ur cd or dvd lens get very very dirty..first try to clean it with the help of cd dvd lens cleaner... if the same erroe is come again then u need to change ur lens..or ur drive..
Jun 06, 2009 | Compaq Armada M700 Notebook
Cant install program from DVD drive GWA-4164b
do you use orginal CD or DVD. if you saying yes. your CD/DVD drive is getting break down
May 27, 2009 | Acer (4432A-002) CD-RW Burner
My asus drw-2014l1t dvd ram drive burning error
Take a look at this registry key - you might have a different GUI id after Volume
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives\Volume{1365b506-f359-11dc-ac07-806d6172696f}
There should be a REG_DWORD called DRIVE TYPE
The values should be 1 for a CD-R and 2 for CD-RW
To verify - Go to My Computer and Right click the CD/DVD drive and then Properties.
You should now have a RECORDING tab and be able to burn CDs and DVDs
You need to re-boot for 3rd party software such as Roxia etc to now see the drive
Aug 16, 2008 | Toshiba TS-L532L DVD±RW Dual Layer...
DVD DRIVE/CD-WRITER
GO TO CONTROL PANNEL
SYSTEMS
HARDWARE
DEVICE MANAGER
CLICK DEVICE MANAGER(WINDOW)
EXPAND CD /DVD ROM DRIVES
RIGHT CLICK ON SELECTED DVD/CD DRIVE
SELECT PROPERTIES
1.SELCT DRIVER ( CLICK UPDATE DRIVER)
2.CHECK DVD REGION CODE.
3.UN-INSTALL DRIVER
4. REINSTALL DRIVER AGAIN(AFTER STEP 3)
OR
IN DEVICE MANAGER RIGHT CLIVK DVDCD ROM DRIVE
UN-INSTALL DRIVER
OK
REBOOT COMPUTER
ADD HARDWARE(CONTROL PANNEL)
IT WILL PROPMPT FOR INSTALLATION OF DRIVER
SAY OK.
PROCEED WITH WINDOW INSTRUCTIONS
DVD/CD ROM DRIVER WILL GET INSTALLED AFRESH.
HOPE IT WORKS.
Jul 01, 2008 | Computers & Internet
HP CD-RW DVD RW COMBO
I HAVE AN HP LAPTOPmag-glass_10x10.gif WITH CD-RW AND DVD RW ON IT BUT WHEN I TRY TO BURN EITHER OF THE TWO IT SAYS DRIVE NOT DETECTED. HOW CAN I MAKE SURE IT IS INSTALLED PROPERLY
Apr 01, 2008 | HP (377402-B21) CD-RW/DVD-ROM Combo Drive
Cd/dvd burner
Check the volume controll on the player you are using. Players like Power DVD etc have volume controlls and mute buttons the mute might be active or the volume is down.
Dec 28, 2007 | Philips 20x DVD±RW Drive Burner
Dell Inspiron 1521 Laptop Logo
105 people viewed this question
Alun Cox
