Question about 2wire Wireless-G 802.11g ADSL Gateway
Says dsl has no connection, but yet on network it says connected. red light flashing on gateway unit
  • 3 Answers
Your computer sees its connection to the gateway - that's your "connected" - without being connected to the internet. First check that all cables are securely plugged in, especially the cable from the phone jack to the gateway device. You may need to cycle power on the gateway device to restore the DSL connection, and you may need to reboot the computer afterward to reconnect to the Internet (depending on your OS).
Posted on Jul 29, 2009
I want to know how I can re-set my 3Com 3crwe955275 wireless access point to its default factory settings. Can anyone help?
1 Remove power from the Gateway. 2 Disconnect all your computers and the cable/DSL modem from the Gateway router. 3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports. 4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway. 5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports. 6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to: http://192.168.1.1 and run the configuration wizard. You may need to restart your computer before you attempt this. 7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
Feb 18, 2015 | 3Com Computers & Internet
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Connection show as good but internet wont come up
Could be a multitude of things, I would check your proxies first.
Go to Tools > Internet Options > Connections > LAN settings.
You most likely are not using a proxy server. Ensure your settings mirror the above, especially the "Use a proxy server..." setting.
One other possability: When you say you can connect to the LAN or wireless connection fine, I must assume you are using a router with wireless capabilities.
Just becuase you can establish a connection to your router, does not mean that router has a gateway to the internet. The router is simply used to create a network for file, printer, and internet sharing. It is totally possible to use the router strictly for networking purposes and not for internet sharing.
That being said, I would ensure the cable/dsl modem is securely connected to the router. Also try power cycling both devices. Check the lights on the modem, typically they give a status. Mine has a POWER, ETHERNET, DSL, INTERNET, and ACTIVITY light. Green typically means status is functional, red means it is not.
When my ISP is down, the DSL light will be flashing red. It is time to call your ISPs tech support if that is the case. Check all your connections to be secure and power cycle everything first, your ISP will ask you to do this as soon as you call them, and it does resolve alot of problems quickly.
There is always the possibility of them having an outage.
General rule is always check the physical layer first, which is cabling and hardware. Make sure it's on and plugged in. Then try rebooting it all.
Hope this helps.
Aug 11, 2011 | Computers & Internet
Im just setting up my 2wire 2701 it works for a few secounds then stops the dsl light is flashing red. Any thoughts?
Hey!
The way I see it, there are 2 options:
1) There's a problem with your phisical internet connection - check the modem configuration and\or contact your ISP so they'll check that everything is configured well on their side.
2) Your router is failing... have it replaced!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Jan 08, 2011 | Gateway Wireless-B Router (wbr-100)
How do you setup xbox live with a wireless connection my router is upstairs but i want to play my xbox 360 downstairs
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :)
Jan 16, 2010 | Microsoft Wireless Network Adapter Xbox...
1800HG DSL modem/router: Cannot access any of the setup pages.
you have to set the unit to default hold the reset button for about 30 seconds the small hole
Jul 11, 2009 | 2wire 1800HG Router (RG1800HG00)
DSL connection keeps dropping off. Going to RED
well!! I have an answer for you.your comp is loosing the IP address.do this when you can go online. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this.
Jul 10, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
DSL Flashing
You dont need both. Do the following:
Unplug your speedtouch from the phone line at the back of the speedtouch unit. Plug that cable into your Zoom. Then plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Nov 23, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
How to use 1800 HG on a non BT IP
i got all green lights on my route and was working a week ago but for some reason it has stop work. please help
Jan 27, 2008 | 2wire 1800HG Router (RG1800HG00)
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
258 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
