Question about Hoover Vacuums
How to replace filter in hoover steamvac deluxe F5864-900
SOURCE: Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Posted on Dec 06, 2007
  • 294 Answers
SOURCE: hoover steamvac spin brush puts
Check for the front panel duct located on the lower tank front. this is the part you need to remove to attach the hose. also check to make sure the lid is on and secure on the lower tank. remove the lower tank and look on top of the motor cover toward the left front corner you should see a round black gasket on a pipe. if not there, this will cause poor suction.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: Hoover SteamVac F7222-900 steamvac Brushes do
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Posted on Feb 11, 2009
AV Nerd
  • 4 Answers
SOURCE: Hoover SteamVac Agility
Press the handle release kick-button with your foot, extend the handle all of the way back, and take a look at the gap between the base of the unit and the handle/reseviour assembly. You should see several black hoses attached to the base and running up into the handle assembly. One of them (the dirty water return hose) might be cracked. Turns out that might be a common problem with this model. We had the same problem.
Judging by the interference between the vacuum hose and the "dirty water return" hose, there is NO WAY those two hoses can exist together in that housing without causing the dirty water return hose can last for many full bends of the handle. We opted to not repair our unit, but you might be able to do it yourself for the cost of the part and several hours of your time. Otherwise, seek out your certified Hoover repair center for more info.
Posted on Jun 18, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
How do I replace the center brush on Hoover SteamVac?H
I would need more information about your problem. If you are referring to the brush block assembly, you should be able to remove it by "pinching" the front and back of the block assy, at both ends and then pulling the assembly out.
Oct 02, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Lost instructions need manuel
Go to:
http://www.amazon.com/Hoover-F5866-900-SteamVac-Deluxe-Cleaner/dp/B00005NWXL
If you scroll down to the "Product Details" section, you have a link to download the manual (1.25mb PDF)
Best Regards,
Aug 06, 2011 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Broken Brush on Hoover SteamVac Need to order new brushes
Yes you can order a brush block. It comes complete it is around $35. You can buy or order them at any vac shop or call me at my shop and I can ship them out.
Josh 614.868.0799 m-f 9:30-6 sat 10-2
Dec 18, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover steam vac deluxe - no suction and the scrubbers aren't spinning uless you tilt off the floor.
I would suspect that your turbine assembly bearings need to be replaced. also check for debris inside the brush assembly. check the intake filter under the front clear cover. verify the recovery tank lid is on securely, as well as the foam filter on the tank lid is clean.
Oct 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steamvac deluxe
Go to Hoover.com. They have free downloadable manuals for all models.
Oct 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41020&thid=565323
Hoover SteamVac deluxe
Posted by stripes9 on May 02, 2008
The solution will not dispense from the machine but will still dispense from the hose.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5866-900 SteamVac Deluxe Wet/Dry. You probably have 2 problems, #1. The trigger assm may be loose or broken and is not releasing the solution from the water solution tank or #2. The valve under the water solution tank could be shot or broken. If so, then the water solution tank is one assm and you would need to purchase a new or a good used one to replace. Please, feel free to check with your local vac dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
