Question about Lands Phones
Palm Treo 750 -calling out show dialling and then within a couple of seconds shows hanging up.I can receive incoming calls.
  • lbunting Jul 29, 2009
    This worked-the pervious setting was on auto and for some reason that stopped working.
    Thank you
Hi there
Seems your phone is having confusing with GSM and EDGE and so hangs up.
Please try the following:
  1. Start
  2. Settings
  3. Phone
  4. Services
  5. Band Selection
  6. Select network type
  7. GSM
  8. Press OK or the appropriate button to save these settings
Now I am unsure if you need to restart the phone at this point. Try making a call, if it still happens, confirm the above settings one more time, save the settings again and turn off and on your phone (turn off fully, not standby).
Hope this helps!
With regards
nLinked
Posted on Jul 29, 2009
Palm Treo 750 "no service"
my favourite (treo 750) i own 1 but not sure i have had that problem yet depending on if you install a program it could be causing that problem maybe a call blocker! u could check to see if ur network is on automatic
start-setting-personal-phone-network-netselection automatic
try backing up your phone data then master reset back to factory setting
N.B you would loose everything that cannot be backed up but this solved my bluetooth problem 1 time holding down the reset button then press power. when prompted to reset say yes
Feb 01, 2010 | Palm Treo 750 Smartphone
4 2 months now, treo 750 keeps hanging up
i think is time for a new phone. sorry
May 02, 2009 | Palm Treo 750 Smartphone
I have lost my palm Treo 750 how to trace where is using my phon
Call your service provider. They can see where the last triangulation of Cells occured and tell you (within 150') where it was when they last polled it.
Cell phones regularly send out signals looking for a carrier (tower) and usually more than one will register the poll. They do that even when turned OFF.. until the battery dies.
Good luck
Mar 26, 2009 | Palm Treo 750 Smartphone
Handling Two Calls
Actually, if you hang up on the two calls, the one call isnt "really" hung up on. Example:
Bob hasa treo and is talking to Phil & Jane swapping back & forth. Bob says goodbye to Phil and hangs up and both calls appear to get disconnected. Jane's phone never hangs up. A few seconds later, BOb's Treo rings again... it's Jane. But to Jane, it's the same call. She was never disconnected. Bob just clicks answer and he's back...
Nov 03, 2008 | Palm Treo 700w Smartphone
Palm Treo 750
Hi Hora
I have a solution for you, your mobile service provider, ie Vodafone, should have a code to extend the length of the ringer before it will divert to voicemail.
For anyone using Vodafone it is:-
**61*+447836121121*10*25#
The last two digits are the amount of seconds you want to have, above is set to 25 seconds.
I have heard on the 'grapevine' that using the full 30 seconds may make a difference to how you are billed, that is a higher charge in the incremental way you are billed. So 25 seconds should be the maximum duration.
May 31, 2008 | Palm Treo 750 Smartphone
Touch screen not responding
There is a treo repair website that shows you how to replace the screen yourself.
May 04, 2008 | Palm Treo 750 Smartphone
Palm Treo 750 camera takes pictures but video not working
how can i change the front panel of the palm treo
750
Feb 10, 2008 | Palm Treo 750 Smartphone
Phone Freezes
If you mean that the phone hangs for a couple of seconds and then hangs up the call - I think I found your solution - http://www.wombatnation.com/2006/03/fix-for-treo-600-hangs My Treo was doing the same thing - so I just reseated the battery connection and it fixed my problem.
May 30, 2007 | Palm Treo 600 Handheld
Lands Phones Logo
22 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
