Question about Samsung L200 Digital Camera
How do I replace the LCD screen in my samsung L200
Cracked screen. need to order one to replace. how to find replacement screen to order and replace.
go to ebay and type in model number of the camera and add screen to the end of the model number to get a listing of screens for your device.
Aug 24, 2012 | Samsung L200 Digital Camera
My samsung L200 digital has vertical lines over the entire screen.I am unable to take any pictures
it is a normal stituation for camera vertical lines problem.you should change your lcd screen or send to the maintance center
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Sep 09, 2011 | Cameras
Hi ihave smashed the lcd screen on the camera can i buy an lcd sceen or where can i get it mended i live in sittingbourne kent. many thanks.
Yes you can purchase a new replacement and fit it. Its not available in your area but you can order it online through the links provided below:
http://www.darntoothysam.com/categories/Samsung-Digital-Camera-Parts-and-Repair-Service/
http://www.amazon.com/SAMSUNG-L100-L110-L200-REPLACEMENT/dp/B002VI7VBK
Jan 18, 2011 | Samsung Cameras
LCD
Are the images also black when you look at them with your computer? If not your screen is either broken or no longer connected properly. The LCD screen can be replaced by a tech savy user and the part is available on common auction websites. There are also independent Camera Repair places that carry the part - Camera Repair NYC
Aug 21, 2009 | Samsung L200 Digital Camera
How much will it cost to fix the LCD
Buy LCD from ebay and DIY replace, ~$40
Aug 16, 2009 | Samsung L200 Digital Camera
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
My l200 has a dark spot on the view screen can this be fixed
The spot sounds like a crack in the LCD screen. You can get LCDs on ebay or from Samsung. They normally plug into ribbon cable connectors but you must be careful not to damage the cable or the connector.
Dec 17, 2008 | Cameras
Samsung l200 digital camera screen broken
Actually, it's super easy to replace the screen. You'll need to order a new one (around 35$, or so). You'll also need a small screwdriver and a small pair of tweezers (actually, eyebrow removing ones will work just fine).
Before you do anything, TAKE OUT THE BATTERY.
Unscrew the screws, remove the front and back casing. Flip the broken screen out of the holder. Follow the orange conductive ribbon round to the other side of the camera, and using the tweezers, gently tug it out of the printed circuit board.
Carefully remove the broken screen.
Take the new one, thread the orange strip back through, and insert it in the PCB slot. Put the lcd screen in it's case, and then put the front and back on, and screw it together.
Watch out for them screws, their small and tricky. don't let them get away from you!
There's a number clips on youtube of someone doing this to a similar camera, but not this model.
This really isn't hard to do, so, yknow, I'd recommend it to anyone.
Dec 04, 2008 | Samsung L200 Digital Camera
Samsung L200 Digital Camera Logo
177 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
