Question about Yamaha CDC-585 5-Disc CD Changer
DOOR KEEPS OPENING instead of playing - Yamaha CDC-585 5-Disc CD Changer
  • 6,784 Answers
Hi. there is a tiny limit switch that regulates the actual CD platform drawer(The part where you lay down the CD). this switch if faulty. it is designed to shut of the load motor when the CD tray is fully inside the unit.
this limit switch must be replaced. this is a job for a qualified Yamaha service tech. contact Yamaha for this repair.
Posted on Jul 30, 2009
How to wire an aftermarket wire harness for a 2002 impala
I have a 2000 impala. Today I just had to buy a $115 wire harness just to hook up my deck and speakers. It's because there's two pieces instead of one to connect to the harness. It's because when u turn your key off ,your radio plays until you open the door. The harness comes with a fan type thing ,that keeps everything from dying.hope this helps
Feb 13, 2013 | 2002 Chevrolet Impala
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
Fridge door doesn't stay open
make sure frige is level left to right. then make back slightly lower than front. while making sure it is level left to right.
Apr 19, 2012 | Refrigerators
When you turn off the truck the music will keep playing until someone open the door but my truck the music keeps going even after you open the driver side. it work right on the passager side
Do you also have a door ajar light lit on the dash all the time. Sounds like the door switch is bad on the drivers door. It is attached to the latch inside the door.
Jun 02, 2011 | Ford F-150 Cars & Trucks
Lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Jun 02, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I have an old Lifmaster professional garage door opener model 1040-6. I just got a new car that has a built in garage door opener. The instructions call for pushing the reset button on the garage door...
THE OLDER UNITS THAT HAVE SWITCHES INSTEAD OF A PROGRAM BUTTON REQUIRE A DIFFERENT PROCEEDURE - YOU USE A REMOTE PROGRAMED TO THE DOOR TO TRAIN THE VISOR.
IF YOU NEED INSTRUCTIONS GOTO HOMELINK.COM FOR COMPLETE SET - PRINT THEM OUT AND KEEP.
HOPE THIS HELPS
Apr 26, 2010 | liftmaster Chamberlain Garage Door Opener...
Player won't read cd's keeps opening door
This model has a belt used for loading the cd mech, after you push play if the belt is slipping or gone,the door will open, if you take the cabinet off eith power off and traopen, look at cd mech you see a belt, it may be loose or gone
Oct 25, 2008 | Yamaha CDC-565 5-Disc CD Changer
Xbox 360 inop
I have a friend w/the same issue. I generally get it to open by holding the eject button down until it does, instead of just pressing it once and hoping.
May 01, 2008 | Microsoft Xbox 360 Console
Yamaha CDC-585 5-Disc CD Changer Logo
334 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
