Question about LG Flatron L1710S 17" LCD Monitor
LG Flatron L1732P won't turn on
Same here... won't turn on. It did like this once before, but after 6 or 7 hours it came back to life. Now... nothing... and no glass fuse here neither. Help please?
  • bboylalu Jul 30, 2009
    Yeah, thanks. I fixed it. It would have been as simple as replacing a capacitor if I had known what to look for.
  • 748 Answers
Hello
The monitor is suffering from power supply failure. I repair many of these daily in my shop or you might find a local repair person.
Posted on Jul 30, 2009
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
Lamp didn't strike
lamps are affected by strikes. each strike erodes a part of the anode. so in essence, the lamp wears out. However a Xenon has a much longer hour life as once it is running, it cares "relatively" little about how long. SO for commercial units, this is an advantage. there are also larger potential issues about colour stability over life.
with UHP, they care only minimally about strikes, it really is not even a strike, so while frequent on and off can kill it early, with normal usage, you are going to be fine. However with a UHP, if a lamp runs for longer times... then you have issues. THe way i had it explained to me was as such;
With a UHP, it gets up to proper operating temp in about 5 mins. once it is there... it SLOOWWWLLLLLYYYYY continues to heat up. After about 2-3 hours, it starts going outside the nominal operating range. once it does so, it starts to degrade the lamp. thereby lowering life expectancy. if you shut it off after about two hours or so and let it cool for ten mins then do it again for two hours... you are in a much better place. In a grand scheme, apparently if you run the proj for an average of 4-6 hours every time, then expected lamp life goes to about 50%. THis is very rough and in a general sense so just take it as general guidelines.
TIPS TO EXTEND PROJECTOR LAMP LIFE:
Lamp life for a projector will vary based on many factors including application, installation, intake of cool air and exhaust of hot air, usage, and proper maintenance. Heat buildup can reduce lamp life and even damage your projector. Here are some tips to help your projector lamps last longer.
Once you turn on your projector, wait at least five minutes before turning it off to allow the fan to properly cool the unit. After the fan has cooled your projector, you may unplug it and store it as desired.
Do not obstruct the air intake or exhaust vent. Paper should not be placed on top of a projector, or where vents are located.
Keep the exhaust vent at least two feet from any object.
If the projector is built into a compartment, wall, ceiling or shelf mount, the minimum distance requirement (usually at least two feet) stated in your owners manual must be maintained.
Clean the projector's air intake filter every three to six months -- or more frequently -- based on your operating environment.
Do not move your projector until the lamp has cooled (about five minutes).
Run your projector for two weeks and/or 20 hours shortly after your purchase. If the lamp is going to fail, it will usually occur within the first ten hours of operation. Lamp warranties typically last just 90-180 days from the date of purchase, rather than the first installation.
When you purchase a replacement lamp for your projector, remove the existing lamp and use the old lamp as your spare. If your projector is new, test the original lamp for the two weeks/20 hours before removing and storing as a spare.
I hope the info. which i have given you solves ur problem if not i am sad to say you have to get it repaired..
Goodluck,
Please don't forget to rate me as fixya..
Feb 11, 2008 | ASK Proxima C170 Multimedia Projector
I have an Omnitech 2gb mp3 player. I have used it previously, as previously as a couple hours ago. I uploaded new music and removed it from the computer, but now it won't work. When I turn it on, it is...
Did you checked that a the HOLD function is not enabled ?
It is a button on the player, allowing you to "block" the player in case of unintentional buttons pressings.
Sep 25, 2011 | Computers & Internet
I have an LG Flatron L1530S monitor. It had been working perfectly fine. However, since a month, when I used to switch it on, the screen would come on, and then become very dim, though the display would be...
More likely to have dying power supply due to bad DC filter caps as you can see in my albums here:
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Failed LG: http://s807.photobucket.com/albums/yy352/budm/LG/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Aug 02, 2011 | LG Flatron L1512S 15" LCD Monitor
Our Sony Bravia Tv was turned off at the wall and now won't come back on, the standby light won't come on, and the fuse is working as we've checked it in other appliances
If theres absolutely no power and no lights on, it sounds like the fuse inside the t.v.. It is pretty easy to change. You have to take out the screws on the back of the t.v. and take the back cover off. Look for a 3/4" glass tube fuse and see if the tiny wire in it is broken. Pop it out and bring it to radio shack and get a new one. Put that one in and try it, Make sure the t.v. has been unplugged for at least 2 hours before opening it so the capacitors have time to drain. They will hold power and could shock you if your not careful. Also, dont use anything metal to take the fuse out.
May 15, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I won an msi wind u130 in a raffle. the box says battery lasts for 7 hours, but when i charged it, it lasts only 2.5 hours. Is there any setting i should change to get the 7 hours?
Welcome to the world of unreal advertising. 3 hours is a realistic max.
You could change the sound to off, the screen to dim, the internet wifi off, etc. to get better battery but of course, that would limit the system.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 03, 2010 | MSI U130416US Netbook
My LG lcd monitor Flatron L1530S goes flashing blinking when i turn on the power button,and the power gone off,
Press and hold the power button on your computer for 8 seconds and release... then press once more to turn it back on.
Sep 27, 2010 | LG L1530S 15" LCD Monitor
Lg Flatron L226wTQ, power button failing
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 16, 2010 | LG 22" FLATRON LCD Monitor
LG Flatron L1710S 17" LCD Monitor Logo
825 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
