SOURCE: Eljer toilet
1) Get rid of those tablets
2) carefully, remove remaining tablet in the tank. Try not to disturb the dissolving tablet. Try covering with small plastic bag, gathering the bottoom together and quickly lifting it out and into the trash.
2) Take either a wire hanger or nail and clean ou all of the small holes around the top of your toilet bowl, undetneath the rim of the seat ring. They are clogged with pill residue.
3) Inside base of bowl, at bottom front is an inlet the stirs the water sothat it all goes down. This inlet is probably clogged with a hard residue. Use either the nail or a serrated steak knife to chip away this residue. It is not slimy; it seems hard as stone and will come off a little at a time.
4) As the residue collects in bottom of bowl, flush toilet, until it works right. It will take a while. I know, I just did this ast night!!!
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
SOURCE: My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
SOURCE: Flush is weakening. Toilet paper won"t flush
Sorry to read about your problem, I hope this helps you out.
i dont think you have toilet issue,
Try this. take a large bucket, like a paint or home depot orange bucket. fill 1/2 way...
put some toilet paper in the toilet. Then pour the water in fast, and see how it flushes. it it does a easy flush then your drain is ok. if its slow, you have a drain issue and not the toilet.
if that the case, then goto the toilet, and clean out all of the little holes, that are around the unit.. where you see the water come out. they can be clogged up. a small type wire like a clothes hanger.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
