Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
I NEED TO KNOW HOW TO SEPERATE THE BRUSHES FROM THEIR PLASTIC INCASEMENT SO I CAN CLEAN THEM . I CAN'T FIND MY OWNERS MANUEL.
    Problem Solver:
  • 15 Answers
Take a scew driver to it
Posted on Jul 29, 2009
Hoover steamvac 50 stopped spinning
Hi! The brushes can stop spinning if something is obstructing them such as carpet fibers, hair, dirt or debris. Remove the brushes from the cleaner by grasping the plastic outer housing and pulling firmly away from the cleaner. Remove any debris and run it under running water to clean. On the back of the brush-block assembly there's a plastic drive pin that rotates all the brushes when turned. Turn the drive pin and ensure that all brushes are making a complete 360° degree turn. If the brushes are getting stuck or if a brush falls out then the brush-block will need to be replaced. Follow the link here to order a replacement brush-block for the Steamvac Search Results. Below is a list of models this brush will fit.
F5912-900, F5914-900F5915-100, F5915-900, F5915-905, F5917-900, F5918-900, FH50041, FH50042, FH50043, FH50044, FH50045, FH50046, FH50047, FH50048CA
Hope this helps!
Jun 20, 2014 | Hoover Vacuums
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes won't rotate on hoover steam vac. I have removed them and cleaned.
The brushes turn by the airflow from the vacuum suction turning a turbine motor to spin the brushes. First try to spin the brushes by hand. If they won't turn it usually means the brushes are clogged with hair and debris or need replaced or the turbine could be seized up. If the brushes won't spin reach under the brushes and push the little tabs and remove the brush block asssembly from the machine. If the brushes spin freely after you remove them from the machine then that means that most likely the turbine is seized and will need to be repaced. If the turbine is not seized you may simply just have a clogged filter screen. Most steam vacs have a red screen filter either on top or underneath the machine. On the top it is under a little clear plastic cover that you have to pry off before you can pull the screen out to clean it. If it's underneath you can pull it out and clean it.
Jul 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
My Roomba says to clean the brushes when the brushes are already clean. Is there something to take apart to check? I have already taken the brushes out. I don't know the model number, I think it's the 500...
turn the unit upside down and remove the bottom pan should be 4 or 5 screws depending on the model.
next remove the 4 screws that hold the brush cartridge and pull the whole brush assembly out.
using a can of compressed air clean that whole assembly out there is a motor there so don't spray any cleaner on it. If there is surface grime you can use a clorox wipe or a damp cloth to get it all off.
this process should take about 10 minutes to do it properly use the straw that came with the compressed air to get in between the plastic shell and get all the dust trapped inside there.
make sure there is no dust trapped in the gears that drive the brushes.
put it all together and it should work.
Jan 12, 2010 | Roomba 3005 Pro Robotic Vacuum
The brushes on the unit do not spin.
try to clean the filter under the machine or the filter behind the clear plastic, were you see the hypnotic disc sprin that lets you know that the brushes are spinning. To remove : the plastic piece that looks like a triangle, ( were the indicator is that lets you know the brushes are turning ) remove by pulling from top, clean lent from screen and reverse your steps to put back on.
Jul 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Kenmore bagless 339123
take the filters out and clean them.try taking the filters out and turn it on and see if you have suction then.if you do the the problem is the dirty filters.ok if you still have a problem feel free to call ma at 314-628-9153 and i'd be happy to walk you through it.vacuum cleaners are my hobby i clean them up repair the then sell them
Mar 01, 2009 | Kenmore Progressive Bagless Upright with...
I have a hoover windtunnel v2 the brushes underneath wont turn ? its suppose to be beltless what do i do to fix this
Are you sure it is beltless? What model do you have? Looking at another manual there may be a seperate on off switch for the brushes but would need to know your model to be sure.
Dec 30, 2008 | Hoover U6630-900 WindTunnel Bagless...
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Brushes will not spin -- broken part
Did deeper, I finally just fixed mine today, I thought the same thing about it not wanting to come apart, but try one more time, and when your almost done, look underneath there is a long plastic piece with two screws almost side by side towards the front, take them out, remove the two rubber hoses on the top side and remove the turbine, opens real easy and clean it out, then wala it' work again...
Oct 16, 2008 | Hoover F7222-900 SteamVac Upright Vacuum
Hoover steam carpet cleaner
does the trigger feel like it is doing anything? if not you may find that your handle lever guard is broke and needs to be replaced. this is the plastic piece at the top of your handle and can be removed by taking out the screw. if this isnt it let me know.
Sep 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
90 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
